oil changes
Old Dec 3, 2003 | 11:30 AM
stupato's Avatar
stupato
oil changes
How many people actually pay to have their oil changed...if so how much?
I'm sick and it's a little too cold out right now for me to brave.
Old Dec 3, 2003 | 12:15 PM
68torino's Avatar
68torino
Around my part of South Dakota I've seen most in the $20 range. Never had it done before but next one I will. Don't have a garage so I work in the gravel. When I do I will be watching the work and will let it idle in parking lot to look for leaks. I figure pick the one that uses oil I like and make sure I get a Motorcraft of Wix filter.
Old Dec 3, 2003 | 01:46 PM
95CobraR's Avatar
95CobraR
I've never paid for an oil change. It costs $1/quart and about $3 for a filter at Wal-Mart. It takes 10 minutes. And I know it was done right.
Old Dec 3, 2003 | 01:50 PM
rebel_ford4x4's Avatar
rebel_ford4x4
its about 10-15 bucks cheaper to do it yourself. and you know it was done right.
if you do decide to pay someone to do it, put a mark on your oil filter so you know they change it. and make sure it is on tight
a girl i work with had her oil filter come off as she was driving because the mechanic didnt tighten it up and it blew the motor.
Old Dec 3, 2003 | 01:59 PM
Texan1983's Avatar
Texan1983
i never go back to those quick lube places. i went there once for a tranny flush and stripped the threads on the lines and in the radiator that it had to be towed out and new radiator and one new tranny line. the stupid guy had the nerve to get pissy at my because the truck was taking up one of his stalls. i almost punched the guy right there! they paid for the repairs finally after claiming that the shop that replaced the radiator did this which wasn't true. they also gave me a apology and a cupon for a free oil change.... i never used it. the tranny in that suburban when out a month after that. never could prove they were at fault.
back on the subject of changing oil... i alway try to space out the changes so that i can make it through the toughest part of winther on one change so i don't work in the cold. but i like to change my oil so often (i like clean oil in my truck, no black stuff for me) that sometimes thats not possible. so i take it to my trusty mechanic and he will do it for 24.99 not bad for have a guy who knows what he is doing.
Old Dec 3, 2003 | 02:05 PM
fordman102's Avatar
fordman102
I change my own oil. I live on a limited budget and little things like oil changes add up. I like putting that money in the fuel tank and burning it up.
Old Dec 3, 2003 | 02:06 PM
blu's Avatar
blu
On the Pickups with plenty of ground clearance its an easy job. If I paid someone I'd expect it would be around $25.
Having a service do it this one time might not be a bad idea. Have your coolant checked as well - might save some grief seeing as how its 0(F) with the windchills the last few days.
Old Dec 3, 2003 | 02:22 PM
stupato's Avatar
stupato
the weathers been pretty crazy here in the northeast...i was planning on doing it this weekend but it went from 60 to 30 pretty quick...and the wind makes it worse...just checked the weather though and its supposed to get above 40 for the weekend...i can definately deal with that...plus all your stories are scaring me...
Old Dec 3, 2003 | 02:35 PM
Matts72's Avatar
Matts72
i gotta change mine before I drive 2450 miles across the country, again .
Its between 10-15 degrees out of the wind up here in the middle of Maine, I hate to htink of how cold it is up in the county!
It costs me $9 to change my oil, the place down the street wants $25 and they put in Pennzoil and a fram filter, yuck.
Old Dec 3, 2003 | 04:09 PM
stRanger706's Avatar
stRanger706
I used to change my own oil, back when I lived at home. But now I dont have a nice driveway to do it in, plus I gotta have that oil drain pan, and then drop the oil off somewhere that accepts it. I just go down to super-lube, I think they are good I mean if you change oil all day and nothing else, you gotta be pretty good at it. And if they do screw something up, just keep the receipt as proof they were last to work on it, and it should be fine right?
Old Dec 3, 2003 | 04:12 PM
wabiker's Avatar
wabiker
...Depends on my mood...but I double check everything when I pay to have it done...
Old Dec 3, 2003 | 08:22 PM
pfogle's Avatar
pfogle
If I pay to have it done it's ~$35 (maxlife, if I do it it's ~$20 ($2 a qt, and 3 for a filter)
Old Dec 3, 2003 | 08:26 PM
fordman428's Avatar
fordman428
well around here if you have it done by a shop its usually 20 bucks if u do it your slef its still not much less than 20, i guess it pays off to know the shop owner.
Old Dec 3, 2003 | 08:28 PM
Andysutt's Avatar
Andysutt
I dont pay for it, but I have once...
The day I got my first car
After that I paid for it myself and done my own work
Old Dec 3, 2003 | 08:41 PM
couleeman's Avatar
couleeman
I end up paying for it with my wife's car, $10 a change. This is only at the dealer we bought the car, for as long as we own the car. I figure I am not going to touch it for that price.
I change my own on my truck. $1.88/quart and $3-4 per filter. I got it down to a 10 minute deal to change and grease. Takes longer to clear a spot in the garage sometimes.
