Another Set Back
Old Dec 3, 2003 | 07:42 AM
jcs1966's Avatar
jcs1966
Another Set Back
Mechanic who installed cam came last night to start motor for "break-in" and it just pours smoke out of the driver side tailpipe and the oil filler cap and even the dist shaft area. When I got truck two years ago it DIDNT SMOKE!!!! but it has been sitting at body shop and mchaanics for two years. I am deeply disappointed and the oil vapor covered everything under the hood!!!! There is a hose from pass side of motor going into carb and it is sucking air when I pull it up out of vavle cover but the smoke is coming from driver side. I didnt tell mechanic but he told me to change oil before he started motor and I got a good sized cup of water before the motor oil drained out. I left it drain for two days. Are the rings stuck from sitting? Should I try some kinda ring unsticker? Will it get better?
Old Dec 3, 2003 | 10:31 AM
daveg66's Avatar
daveg66
The hose from the valve cover to the carb is the PCV, it is supposed to have vacuum on it. Sounds to me like a stuck ring or bad valve seal. You might want to try posting in the appropriate engine forum for some better ideas.
Dave
