Motorhomes (Class A,B,C & Super C) F-53/59, E-Series E-350 / E-450 RV Cutaways, Econoline, Transit, Stripped Chassis, Bus Conversions
V10 tapping?
Old Jan 29, 2025 | 02:08 PM
Mako25's Avatar
Mako25
5th Gear
V10 tapping?
Our 2013 Ford v10 in our tiffin motorhome is tapping. The motorhome was recently taken out of storage (1year) we drove the motorhome a couple hundred miles not a problem. Now after sitting at new site for the past 4 months we decided to move on. When I started it this morning it had a pretty good tic . There are 68000 mi on it, oil was changed just prior to putting in storage so same oil 1 year old but only 200 mi. use. We have had and maintained this motorhome for the past 5 years and never had a problem. When the motor starts it runs smooth as a ever just the tap. Oil pressure is fine. Could it be the old oil?
Old Jan 29, 2025 | 08:49 PM
Ted722's Avatar
Ted722
Does it go away after warmed up?
You running 5w20 or 5w30?
I had 5w20 in mine when I first bought(92K miles), put 5w20 in next oil change and still slight tic on startup (5 seconds) then quiet.
Wanted to switch to 5w30 anyway as it’s the original oil weight spec’d for these motors. Have had 5w30 in it the last 2 oil changes and tic on startup is gone. That’s been 10,000 miles or so. Truck has 106K miles now.
Old Jan 30, 2025 | 08:46 AM
Mako25's Avatar
Mako25
5th Gear
I only let it run for a few minutes. I am going to change oil and check my plugs.
Old Feb 2, 2025 | 12:22 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'm curious what the tap does after like ten minutes of idling.
Old Feb 2, 2025 | 09:19 AM
Mako25's Avatar
Mako25
5th Gear
It continues. I had it looked at and it seems like a lifter on drivers side.
Old Feb 2, 2025 | 12:07 PM
CathedralCub
FTE Community Team
What oil are you using (brand, grade, and weight)?
Old Feb 2, 2025 | 01:28 PM
Mako25's Avatar
Mako25
5th Gear
5 30 full synthetic
Old Feb 3, 2025 | 03:21 AM
charlie g's Avatar
charlie g
FTE Community Team
is it a tap or a pop, the v10's were good for exhaust manifold leaks due to snapped 8mm studs holding the LONG manifold to the head
Old Feb 3, 2025 | 11:35 AM
Mako25's Avatar
Mako25
5th Gear
Great question. There is one missing bolt on the passenger side exhaust manifold. The other bolts look pretty bad also.
Old Feb 3, 2025 | 01:46 PM
charlie g's Avatar
charlie g
FTE Community Team
my 05 v10 had both manifolds warp,popped several studs ,what a nightmare to fix, sounded just like a lifter cold
Sarasota
Jun 20, 2012 03:09 PM
Fred D.
Modular V10 (6.8l)
32
Dec 2, 2006 01:51 PM
BigFord74
Modular V10 (6.8l)
22
Oct 24, 2005 08:01 PM
bcnu2004
Modular V10 (6.8l)
Feb 28, 2005 02:24 PM
Nutz5
Jul 5, 2003 06:12 PM
