Got a problem
Old Jan 28, 2025 | 05:28 PM
Mike8623's Avatar
Mike8623
Got a problem
Exe has been running fine. Went out this morning to start it and it would start but not like normal. It started but the check gage light came on and in the message center it says low oil pressure and the oil gauge is not working. It will also not move when you put it in reverse or drive.
Any ideas.....could it be a fuse. I've had the battery charger on it all day.
I did change the oil and filter last week and oil level is fine.
the battery light is also on.
Old Jan 28, 2025 | 06:58 PM
Mike8623's Avatar
Mike8623
OK guys got it solved.
I just took the negative battery cable off the post for 30 sec. And reattached.......all is back to normal.
Old Jan 29, 2025 | 08:50 AM
alloro's Avatar
alloro
Could also be the oil pressure sensor acting up. If it happens again, I would change it.
Old Jan 29, 2025 | 08:51 AM
Mike8623's Avatar
Mike8623
Thanks
74Mav
Modular V10 (6.8l)
Jan 1, 2018 09:23 PM
pomial
May 23, 2008 05:06 PM
Ammon
Nov 13, 2004 07:08 PM
victorino
Feb 23, 2002 02:17 AM
