Stuck in 4WD?
Old Dec 5, 2003 | 06:19 AM
emtabmm's Avatar
emtabmm
Originally posted by nosbor
wheels do not move
Its locked in....
Old Dec 5, 2003 | 06:27 AM
nosbor's Avatar
nosbor
Thanks
In what direction do I point my dealer to unlock it?
ie: Hubs, Transfer case, etc, etc
Old Dec 5, 2003 | 12:22 PM
Scurv's Avatar
Scurv
Put it in neutral....press the brake pedal as hard as you can and hold it down then turn the selector to 2 high. If that doesnt work then review these links. Crawl underneath and check the connections. Think these post were geared more toward Broncos but may be helpful as a reference.
http://fordtrucks.com/forums/showthr...t=%25252Bstuck
https://www.ford-trucks.com/framered...3d800a47e5.jsp
ps. I spent 70 lovely days in Seeb back in 91. Mountains were beautiful.
Bob
Old Dec 11, 2003 | 07:10 AM
Scurv's Avatar
Scurv
did it work??
Old Dec 11, 2003 | 09:50 AM
nosbor's Avatar
nosbor
No it didn't work, but thanks to everyone for the input. Because of the information learned from everyone, I was able to point my mechanic in the right direction. As it turns out the transfer case clutch plates were worn and bent. The case that they were in had signs of extreme heat and a small metal disc (don't know what it's called!!), had a major crack, so all in all managed to get to the bottom of the problem before anything too serious happened. Cost 230 rials which is approximately 500 USD to fix, I think it could have been a lot more expensive without everyone's help. Thanks for the input Pete
cranegrad
Sep 23, 2016 10:45 PM
Jimmy Dean
Feb 2, 2014 09:25 AM
Jimmy Dean
Offroad & 4x4
Jan 28, 2014 07:41 PM
TobiasR.
Oct 1, 2011 08:57 AM
longhorns13
Sep 30, 2009 09:12 PM
