Sponsored by: Auxito
inside windshield condensation.
Old Jan 27, 2025 | 04:04 PM
panel's Avatar
panel
1st Gear
Hell My 2001 f150 gets condensation covering the inside of the windshield .It hasn't rained and the floors aren't wet or anywhere else for that matter. Just the windshield. I put an RV drysair in and it does gather water. Again it's not water from rain ,heater core doors or windows.I been told it's the moisture in the air with the sun warming up inside the truck and cooling off at night. Anyone else experiencing this?
Old Jan 27, 2025 | 04:14 PM
Jon Freeman's Avatar
Jon Freeman
I've never experienced that problem and I live in the Pacific NW. It rains a lot.
Sounds like you have a moisture leak somewhere......
Old Jan 27, 2025 | 04:56 PM
panelguy's Avatar
panelguy
That's what I though but it hasn't rained for two weeks and the floor ,doors are dry just on the windshield. I'm sure it's condensation. Talked to a neighbour who has a F150 with the same problem. I live in Southern BC..Not much I can do about it I guess these trucks aren't air tight.
Thanks Jon.
Old Jan 27, 2025 | 05:02 PM
Mountain Whiskey's Avatar
Mountain Whiskey
Do you run the heat on defrost regularly? You might already know but it runs the AC with it. If your drain is plugged it might be that.
Of course it could be the seal at the ECU.
The foam seal around the AC drain.
The rear brake light leaking down behind the seat and rear panel.
The rear window doing the same.
Cab pressure relief vents in the rear leaking.
Rust behind the heat shield and under the rubber where the carpet ends at the firewall.
Bad door seals.
Rust eating through the floor pan.
Windshield seal leaking.
Drain in the cowl clogged up.
I really doubt it is a cool dewy morning in your truck.
Old Jan 27, 2025 | 06:42 PM
BareBonesXL's Avatar
BareBonesXL
How much is collected? What is this "drysair" thing, one of those buckets with pellets or a machine?
Second thought - actually a lot depends on how you drive, where you park, and where you live. There's no real information here, just "inside of windhield gets moist".
Old Jan 28, 2025 | 04:34 AM
manicmechanic007's Avatar
manicmechanic007
Your heater core leaks
That is most likely what is putting the condensation on the windshield
Temporarily block off the heater hoses as a test for a few days
Old Jan 28, 2025 | 08:31 AM
panelguy's Avatar
panelguy
No heater core smell and it's after sitting for a few days that it gets wet inside on the windshield. Thanks.
Old Jan 28, 2025 | 10:26 AM
BareBonesXL
Are you using antifreeze or straight water? You won't get much smell with just water.
You probably have water under the floor material (carpet or rubber) and in the various crevices, like under the door sills. It's not visible but it will still vaporize and recondense.
Good luck. You'll get more detailed possibilities if you add more details to your posts. There's kind of a correlation.
Old Jan 28, 2025 | 08:35 PM
Im Wrecked's Avatar
Im Wrecked
5th Gear
My guess is you have a slight heater core leak.
Old Jan 29, 2025 | 12:37 PM
J. Bruce's Avatar
J. Bruce
+1 on heater core leak. In BC he will have antifreeze but I have had a few go bad with and never have been able to smell it first. You could leave it in the sun with the windows down and get rid of the condensation on the windshield. Then close the windows and run the defrost and if it comes back in a few minutes you know its the heater core. This is how it would work in heater cores I have had go bad anyways.
Anonymous12
Feb 21, 2024 11:02 AM
message
6.7L Power Stroke Diesel
Jun 28, 2022 06:21 PM
casper1999
1983 - 2012 Ranger & B-Series
Oct 30, 2013 03:42 PM
snyiper
Oct 9, 2005 08:20 PM
xbi0s
Bronco II
Apr 8, 2002 02:29 PM
