1978 - 1996 Big Bronco
Now what!!
Old Dec 3, 2003 | 12:31 AM
Ben242's Avatar
Ben242
Now what!!
Me again,
I was going through a big puddle when all of a sudden my Bronco shut down. No bogging just turned off. I tried to restart but all it would do is click. The power is all there but it just won't turn over???? Does anyone know what it might be? I seem to learn something new everyday, but it is always the HARD way!!
Thanks
Ben
Old Dec 3, 2003 | 12:57 AM
rlh's Avatar
rlh
Ben, Is the engine turning when you try to start it?
Is it getting fuel?
Old Dec 3, 2003 | 01:09 AM
Ben242's Avatar
Ben242
No, the engine is not turning. All I get is a click and all the lights in the cab go dim.
Old Dec 3, 2003 | 01:16 AM
rlh's Avatar
rlh
First, make sure the charging system isn't wet...try jump starting it. If the engine "locked" up you would have probably noticed.
Old Dec 3, 2003 | 01:32 AM
Ben242's Avatar
Ben242
I tried jumping it but no luck!
Old Dec 3, 2003 | 01:43 AM
mrit's Avatar
mrit
Pull all the spark plugs then turn the engine over. Check if any water comes out of the holes. Hopefully you didnt hydrolcok it.
Old Dec 3, 2003 | 02:08 AM
90ebbronc's Avatar
90ebbronc
Hydrolock, is that where u flood out the engine in water and it locks it up? .... Thats why i stay away from water as much as possible!!!
Old Dec 3, 2003 | 10:25 AM
kevinswart's Avatar
kevinswart
Did you check the starter? If it is just clickin that would be my guess. I would pull the plugs and make sure there is no water in there. Then with the plugs out try to jump it again. If it is still clicking have someone else try and start it...get under the truck and gently hit the starter a few times with a hammer. If it starts you need a new starter. If it doesn't and you find the clicking is coming from the starter you probally need a new starter
Good Luck
Old Dec 3, 2003 | 10:31 AM
Kemicalburns's Avatar
Kemicalburns
i say starter or the solenoid on the firewall is toast. both easy fixes .
late
Old Dec 3, 2003 | 04:47 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Jump the solinoid switch and if the starter does the same thing it's probly your starter. Also, when your under there check all the conections, loose connections can cause all of this.
Old Dec 7, 2003 | 12:57 AM
Ben242's Avatar
Ben242
Well, I think I hydrolocked my engine My buddy took the starter out and made it go. He stuck it back in place and tried it but no luck! This sucks! I am going to pull the top off and check the rods and see if any of them are bent or if the piston is stuck. I just might have to drop 1500 for a new engine!!!!!!!!!!!!!!!! Do you ever just want to kick your self in the JUNK!
Old Dec 7, 2003 | 02:44 AM
mrit's Avatar
mrit
Pull the plugs before the heads! If there is any water in there it will be pushed out.
Old Dec 7, 2003 | 03:14 AM
Ben242's Avatar
Ben242
Ya, We already pulled the plugs and water was in there.
Old Dec 7, 2003 | 11:01 AM
Norm Carter's Avatar
Norm Carter
When the plugs are out, will the starter turn the engine over? If not, I think you're looking at the solenoid.
Old Dec 7, 2003 | 03:14 PM
Ben242's Avatar
Ben242
No, the starter will not turn the engine over. My buddy tried to crank the engine by hand but it wont move. Will the solenoid do this??
