View Poll Results: It is worth deleting, or keeping the warranties
Worth It
18.00%
Not worth it
42.00%
wait until warranties are gone
40.00%
Voters: 50. You may not vote on this poll
2024 6.7 delete
Old Feb 3, 2025 | 06:37 PM
  #46
Tib's Avatar
Tib
Originally Posted by acdii
Regardless of what happened with the EPA and their being smacked down, it doesn't prevent any state from enacting their own emissions testing. If a county where there are a bunch of deleted trucks decides to start doing emissions testing, what are the deleted owners going to do? Drive around with expired plates? Wont be able to renew without a valid smog test. Not to say it's going to happen, but what if it does?
What if one decides to take a trip to CA and is forced to do an emissions check when across the border. Then what? They still enforce emissions checks regardless what the feds did with the EPA. It's cCommiefornia for a reason.
There are exceptions, for example if you don't live there and your permanent state of residence is elsewhere you don't have to do emissions testing. That doesn't mean you're wrong, they sure could do that if they want.
When I lived there while in the military we kept our out of state tags, insurance, and never had to do emissions.
I lived in a county where they did the emissions testing every year, and they exempted diesels. This was before the rolling coal became a big problem around here and I expected them to remove that exemption, but they just removed the testing all together. $10 a year, ODB hookup and as long as the "testing period" was over after a code clear it was good. Felt like a waste of time and a cash grab.
Old Feb 3, 2025 | 07:32 PM
  #47
kayakingpoodle's Avatar
kayakingpoodle
What if one decides to take a trip to CA and is forced to do an emissions check when across the border. Then what? They still enforce emissions checks regardless what the feds did with the EPA. Its Commiefornia for a reason.
There is a thing the tax collectors love, that is collecting taxes, that said just regiter your vehicle in a county that doesn't do emissions testing. It is only a ups store away.
Old Feb 4, 2025 | 10:11 AM
  #48
jimmystoys's Avatar
jimmystoys
Thread is full of info, unfortunately it's not involving the OP, which is what drew me to it in the first place...
Old Feb 5, 2025 | 07:20 PM
  #49
WXboy's Avatar
WXboy
If I could do it over again I would wait until my emissions system failed and was going to cost me thousands of dollars to repair and then I would delete the truck. Reason why is because who knows what might happen 4 years from now? Maybe the EPA craziness goes wild again. And also it is nice to have a warranty intact because everything on these trucks is very expensive to repair.
Old Feb 5, 2025 | 07:37 PM
  #50
Walleye Hunter's Avatar
Walleye Hunter
How hard is it to reverse the procedure if you keep the parts?
Old Feb 6, 2025 | 12:42 PM
  #51
acdii's Avatar
acdii
Matter of bolting it all back on, plugging in the sensors and putting the OEM tune back in. Some who have areas that do have emissions will do the swap, have it tested, then pull it all back off. On the 2019 I had considered it, but now that I have a 24, no need, I feel Ford has the emissions ironed out so that it has a long life and doesn't use nearly as much fuel as it used to.
Old Feb 9, 2025 | 06:40 AM
  #52
IADiver's Avatar
IADiver
One more thought, Dealers are now not taking deleted trucks on trade. If they do, they figure the cost of putting back to stock. A bunch of new reporting came about recently.
Old Feb 9, 2025 | 09:01 AM
  #53
Walleye Hunter
Rule #1 about Delete Club...Nobody talks about Delete Club.
Old Feb 11, 2025 | 02:32 PM
  #54
acdii's Avatar
acdii
Probably because EPA has been cracking down on dealers selling these trucks and they find out now it is not worth taking the risk. They risk the loss of the dealers license. A far bigger issue than just paying a fine.
Old Feb 11, 2025 | 08:05 PM
  #55
BadDogPSD's Avatar
BadDogPSD
We live where annual smog checks are required. I'd be curious to see the test results to see the true impact of all the added smog equipment on diesel trucks that's required now. I do appreciate having clean air to breathe, but...
Old Feb 12, 2025 | 08:04 AM
  #56
Maxium4x4's Avatar
Maxium4x4
Supreme court is taking up California's emission mandates, see how it turns out. EPA got back handed for stepping out of bounds, owners and after market suppliers do not have to experience unjust behavior. After market suppliers are once again offering more. EPA went rogue and ruled any vehicle with a VIN was subject to emission standards which set the racing industry off.
Old Feb 12, 2025 | 09:30 AM
  #57
acdii's Avatar
acdii
Balancing act for sure. Diesel particulates are very bad for those who have breathing issues. Prior to ULSD, the fumes had a pleasant smell to them to me. I remember the Chicago busses from when I was a kids, the smell as they went past, or the trucks, take a deep breath, just smelled so good. Today though, it burns my sinus and throat and can make it hard to breath. It does not have the same smell to it and in that I am glad the trucks have DPF, though the smell out of those is obnoxious as well, but without the stinging and burning.
What the emissions controls have done is cleaned the air noticeably. I remember back in the 70's early 80's coming home to Chicago from a trip to upper Wisconsin, Minog, Hayward area, and knew we were getting close to Chicago as the view ahead had a brown bubble of air. Today, that brown bubble is gone. The air is much cleaner today than it was 20 years ago. To me its worth the hassle of DEF and regens. The air my Grandchildren will breath will be cleaner than the air I breathed, and that my children breath. There is a stopping point for cleaner air, I think we have reached it. We just need to rest of the world to catch up to our clean air standards.
Old Feb 12, 2025 | 01:39 PM
  #58
Walleye Hunter
I can understand that and think it's fine where it's needed but why would a farmer in rural Iowa or a rural resident in Upstate, NY have to comply with costly regulations that are unneeded there?
Old Feb 13, 2025 | 03:28 PM
  #59
acdii's Avatar
acdii
Because Tractor pulls at the state fair dumps a years worth for every tractor in the state?
Old Feb 17, 2025 | 03:18 PM
  #60
Bret Marstellar's Avatar
Bret Marstellar
Trailering
I'll worry about the exhaust from deleted passenger trucks and tractor pulls once the EPA starts going after all the non-regulated cruise ships, cargo ships, aircraft, etc. Any one of those sources alone dump more pollutants into the air every year than all the passenger vehicles on the road around the world combined.
