6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Radiator leak
Old Jan 25, 2025 | 08:56 PM
Roadtriptruck's Avatar
Roadtriptruck
Radiator leak
Well, after reading about how terrible the radiators are for this truck in the last 10 years of me owning one it finally happened.
What are some solid replacement solutions? All Ears.
Thanks~
~Matt
Old Jan 25, 2025 | 09:08 PM
Roadtriptruck
Went to Rock Auto first of course and found this radiator by CSF which I've seen mentioned before as a high-quality unit but only for their all-aluminum radiator. Not sure I want to shell out that much just yet being as my plastic OEM unit lasted all 10+ years of my ownership and quite possibly the first 6 years of the truck's life.
Any thoughts?
More Information for CSF 3642
Old Jan 26, 2025 | 10:02 AM
2010F350SD's Avatar
2010F350SD
4wd Low
Radiator
About 6 years ago I went with the Mishmoto all aluminum radiator and it has been working great.
Old Jan 28, 2025 | 11:54 AM
Antonm23's Avatar
Antonm23
From what gather its not really the radiators that are junk, its the flex of the core support that's causing otherwise good radiators to crack.
Old Jan 28, 2025 | 12:33 PM
Roadtriptruck
When you say core support, do you mean the frame on the truck which it’s mounted or the actual structural integrity of the radiator?
Old Jan 28, 2025 | 02:27 PM
Antonm23's Avatar
Antonm23
The parts of the body the radiator bolts to. One piece is even removable at the top. The rest is part of the body/ cab structure , not part of the vehicle frame (there are even two body mounts below it. See the red circled areas in the pic below. From what can tell, this is what flexes out of shape (most likely due to bad/ deteriorated body mounts) and cracks the radiators.
Old Jan 28, 2025 | 02:51 PM
Roadtriptruck
The parts of the body the radiator bolts to. One piece is even removable at the top. The rest is part of the body/ cab structure , not part of the vehicle frame (there are even two body mounts below it. See the red circled areas in the pic below. From what can tell, this is what flexes out of shape (most like due to bad/ deteriorated body mounts) and cracks the radiators.
thank you for this, very informative!
Shadhurst76
2015 - 2020 F150
Jan 27, 2024 11:25 AM
rtcapo 61
Sep 8, 2019 01:43 PM
justcruzin125
Jul 6, 2015 09:24 PM
strokeman
Feb 22, 2007 10:49 PM
MemorexKid
1997 - 2003 F150
Feb 15, 2004 09:35 AM
