heated DEF line from tank to injector is that code, mine did the same code last week here in Rochester and i just got it back from the dealer on Wed. mine was covered but mine is a '22 with 14k on the clock. i think that may only be under the 5/50 warranty so you may be out of luck? theres a video on youtube on how to replace that line, doesn't look bad if you have access to a lift, working on the ground it may suck.....
Ohmed it out out of spec (3-6 ohms) it reads 3k ohms so its open and bad.
So called dealer today.
NOT COVERED under out of warranty 2020 F350 81,100 Miles $479.99 plus tax to change out,
Part number HC3Z-5J249-EE $238.01 my cost. Looks pretty easy but not sure I have the time.
I'd search around some, pretty sure you can find it cheaper, and an independent shop would install it cheaper.
I don't think it takes even an hour book time to swap it.
