how much does this raise the height of the truck and bed? I pull a 43' DRV and bedrail clearance is already too close while trying to maintain a level rig
That is a great tire choice , I have run them on several trucks ... Did you have the Spare tire done ? Only big issue people run into mounting 920's on stock wheels is rotation of tires .
My last set I put on 19.5 x 6.75 wide Accuride but they were steels , they sit a lot flatter than mounted on 6.0 rims .
Truck looks good .
If you compare the differences in tire diameter and then cut it in half for how much is raises the truck, its about 1 inch. (31.7->33.6)
The tire is only approved for 6.75" though, and we have 6" wheels. I doubt Les Schwab would be willing to install them.
I run the Cs on my '17 450--no weights. They recommend you not run weights with the Cs.
Wish my truck was the Ruby Red, beautiful!!!
Mind saying what the cost of the Toyos were?
I’m thinking about pulling the weights off of the front and outer rear tires. The cost of the new tires were less than $2,400 installed. I have a buyer for my takeoffs which will offset the cost. At 65MPH, I’m turning 2,000 RPM’s.
