Power Drop Between Shifting Gears
Old Jan 22, 2025 | 03:19 PM
Jevans1405's Avatar
Jevans1405
4wd Low
96 F250 with automatic trans
When the truck is about to shift, the power drops a good bit and the truck feels like its dragging until it gets to the next gear. Happens going up and going down. The engine rev noise and exhaust sound muffled when its happening and you can hear a little hiss in the cab while it happens.
Old Jan 22, 2025 | 05:52 PM
z31freakify's Avatar
z31freakify
Seems like you exhaust back pressure valve (EBPV) is closing and it's normal to some extent in cold weather, but sometimes they get stuck in the closed position due to rust and carbon build up or the spring is weak not allowing the valve to open.
Old Jan 23, 2025 | 09:22 AM
Jevans1405's Avatar
Jevans1405
4wd Low
It's definitely been colder here than usual, but no lower than 15F. Does what you suggest align with the issue occurring right before the truck shifts up or down? Also, would the hissing be the boost then? It almost sounds like AC blowing softly until it shifts, its not super loud.
gtadim
Apr 21, 2024 08:39 PM
Saxon
2015 - 2020 F150
Dec 10, 2022 11:50 AM
mblanken881
2009 - 2014 F150
May 21, 2009 08:09 PM
the_oil_jockey
Nov 28, 2006 12:37 AM
mybigredford
Nov 10, 2004 11:53 PM
