Electrical issues intermittently
Old Jan 21, 2025 | 06:24 PM
Anonymous12's Avatar
Anonymous12
I have a 1988 F-150. I’m having intermittent electrical issues. I just had to slam on the brakes very hard, and now the blower motor, ac compressor, my CarPlay screen on fuse 6 (speed control/shift on the fly), and maybe some other things I don’t know yet are having issues turning on and off. I shook some wiring around, (including my viper alarm/remote start. I couldn’t replicate the issue. But it did it on and off 2 times in the 15 minutes I spent looking. Anyone know of a connection that has all these things in common? I did push on the ignition switch connector, on top of the column. Not the wires though. Ran codes KOER. Just got the 34 and 44 that were already existing
Old Jan 21, 2025 | 09:31 PM
Prototypemech's Avatar
Prototypemech
Check the ground wire terminals behind the driver's and passengers kick panels. Those are the main grounding points for the cab electrical.
Old Jan 23, 2025 | 02:39 PM
Anonymous12
I didn’t see any grounds behind the kick panel. But I can’t get the power to cut out anymore. I hit EVERY bump on our dirt road, and slammed on the brakes. So I can’t test if it’s losing power or ground. I took my power probe with me to test the ground under the dash I have the screen on, since that’s the most accessible of everything shutting off and if it didn’t have ground I could send ground to see if it came on. But like I said it didn’t shut off again.
Old Jan 23, 2025 | 03:55 PM
Prototypemech
On 9th gen trucks, the grounds are behind the kick panels. It may be different on 8th gen trucks.
tekrsq
16
Aug 13, 2023 07:35 PM
paulwjax
Jun 18, 2011 12:55 PM
bobickey
Jan 18, 2009 02:45 PM
apollo95
Sep 24, 2006 07:44 PM
skeneguy
Electrical Systems/Wiring
Mar 29, 2004 10:22 PM
