1995 Ranger A?C Issues...This is gonna be a tough one to answer!
Hi everyone. I think I am going to stump all of you on this one! So, I just got this 1995 Ranger 2.3 4cyl from my neighbor. It has 134K on it. He told me that the A/C doesn't blow cold. So, I go to change all of the fuses in the car. Now, it doesn't blow at all! So far, I changed the fuse, changed the relay. What else? Bad enough the compressor never kicked on, but now it doesn't even blow at all! Help!!!
Thanks!
Dave
Thanks!
Dave
NO AIR AT ALL COMES OUT OF THE VENTS? On heat, A/c, defrost, vent, floor,... nothing?
AND the compressor doesn't kick on?
Ok.. first question.. why did you change all the fuses? Fuses don't go bad due to age. Is it possible you misplaced one or left one out? Or maybe it was missing in the first place.
Second question... did it blow BEFORE you changed fuses?
The compressor not kicking on can be any of a huge number of things. You're going to have to check some things and get back to us, as we could spend all day telling you possible failures.
Is there power going to the blower motor? Does it have freon in it? Does it have power going to the blower switch?
It gets even more strange
Okay, so I replaced the fuses becuase, while almost all of them weren't blown (including the A/C), most of them looked a little charred. I thought that it would be a good measure to replace the fuses on an 11 year old truck with 134K on it.
Here's where it gets strange. So, tonight, I went to autozone to get some throttle cleaner, and the A/C compressor kicks on and off a few times. However, it only blew (very weak) when I was driving. When I came to a stop, it stopped blowing. I replaced my battery and A/C cycle clutch switch. It didn't help at all. Now what?
Now what?
***Fuses do not go bad with age. Just imagine how many cars would be sitting on the side of the road dead if they did .
