Engine swap?
Old Jan 21, 2025 | 01:48 PM
daxclemens3's Avatar
daxclemens3
4th Gear
Engine swap?
I have a manual 1990 f250 Xlt lariat with a 5.8 liter engine and was wondering if I can engine swap it with the 1990 7.3 diesel engine?
Old Jan 21, 2025 | 02:08 PM
rla2005's Avatar
rla2005
The diesel engine will not up to the small block transmission bellhousing. It's a big swap that involves more than just the engine.
Search results using keywords "diesel engine swap" in this forum: https://www.ford-trucks.com/forums/s...rchid=35568023
Old Jan 21, 2025 | 02:12 PM
daxclemens3
4th Gear
Would I only have to switch the tranny and the engine?
Old Jan 21, 2025 | 02:30 PM
rla2005's Avatar
rla2005
Fuel system, additional battery cables/mount, most of the engine compartment and dash wiring, exhaust, the list continues.
What is the goal of this proposed project?
Old Jan 21, 2025 | 02:33 PM
daxclemens3
4th Gear
My main goal of the project would be a towing/off-road pick up.
Is that unrealistic?
Old Jan 21, 2025 | 02:48 PM
85e150's Avatar
85e150
Yes.
Sell, trade, horse trade your current running, factory original, reliable, serviceable truck for the truck you want. Which will be a factory original, reliable, serviceable running truck.
Old Jan 21, 2025 | 03:26 PM
rla2005's Avatar
rla2005
Unless you have a complete donor diesel engine truck of a similar year range, your swap is going to be very expensive and time consuming. Even with a complete donor the time involved is a lot more than you may expect. In the end you wind up with a frankentruck that tends to be very hard to sell. If the current 5.8L engine is in good shape mechanically it is a decent engine to use for towing.
Jakescott
General Automotive Discussion
Mar 17, 2025 11:21 AM
Dillon lalonde
Apr 19, 2024 02:21 PM
forango
Jun 9, 2022 07:39 PM
renchr01
2014+ Transit
Mar 7, 2022 07:47 PM
cthusker
Jul 8, 2021 09:24 AM
