Engine swap
Old Apr 18, 2024 | 09:34 PM
Dillon lalonde's Avatar
Dillon lalonde
4wd Low
Engine swap
If I take the engine outta my truck and buy the exact same engine with the same component placements and put it in and reconnect everything should it work
Old Apr 19, 2024 | 03:01 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Yes? Or you could get a long block and swap everything over from your old engine. Do not use any wiring from the “new” engine. What are you working on and what vehicle is the donor engine from?
Old Apr 19, 2024 | 07:04 AM
Dillon lalonde
4wd Low
I have a 94 f150 with a 302 engine is from 93 f150 that I’m gonna put in no wiring changes just put in my truck should it run n
Old Apr 19, 2024 | 10:08 AM
Dillon lalonde
4wd Low
Both engines are 302s
Old Apr 19, 2024 | 01:50 PM
Conanski's Avatar
Conanski
You must use the '94 engine harness, any wiring that comes with the '93 has to be removed and discarded.
Old Apr 19, 2024 | 02:04 PM
Dillon lalonde
4wd Low
[im gonna be using the harness that’s already in the 94 and reccnnect it when the motor is back in should that work
Old Apr 19, 2024 | 02:10 PM
charlie g's Avatar
charlie g
FTE Community Team
yes if you swap all the external parts from the 93 to yours .IE distributor, alternator sensors, gauge senders, exhaust parts, emission parts
Old Apr 19, 2024 | 02:12 PM
Dillon lalonde
4wd Low
I’m putting the 93 motor in the 94 so all I’d have to do is swap all the exterior parts
Old Apr 19, 2024 | 02:17 PM
charlie g's Avatar
charlie g
FTE Community Team
yes move from the old to the new
Old Apr 19, 2024 | 02:21 PM
Dillon lalonde
4wd Low
[swap new parts to the 93 engine. get motor in plug all the stuff back in and reconnect and should start right up
Jakescott
General Automotive Discussion
Mar 17, 2025 11:21 AM
forango
Jun 9, 2022 07:39 PM
renchr01
2014+ Transit
Mar 7, 2022 07:47 PM
cthusker
Jul 8, 2021 09:24 AM
pidford
Sep 29, 2004 04:48 PM
