Body Control Module Issues?
Old Jan 20, 2025 | 04:38 PM
immurator's Avatar
immurator
1st Gear
Some weird electrical issues on my F150.
Initial cause: dead battery due to leaving an electrical device plugged into the cigarette lighter. Jump started (correctly).
Symptoms: Hazard lights always on, no turn signals, no cruise control, no door locking by pressing on the door buttons, warning light brake fluid low (it isn't), and warning light saying parking brake on.
I've taken it to the shop and they said it was the Body Control Module. They replaced it, which solved the problem, but it started up again in a couple of days. Replaced BCM again. Problem Recurred again. Getting ready to take it back to the shop, but just wondering if any of you all have ever seen anything similar?
Especially an 'invisible' issue that might cause BCM's to go bad repeatedly?
Thanks for any advice!
Old Jan 20, 2025 | 05:10 PM
RLXXI's Avatar
RLXXI
Check the grounds behind both kick panels, take em loose, scrape off any paint/dirt etc then bolt em back up.
Old Jan 22, 2025 | 06:34 PM
quirk625's Avatar
quirk625
Also the one on the under side of front passenger floor board.
Loftatsea
Mar 22, 2024 09:47 AM
1ole4d
Nov 12, 2023 03:24 PM
tomduncan1
Electrical Systems/Wiring
Jun 27, 2016 03:15 PM
alie-r
Feb 9, 2010 10:49 AM
mamag5770
Mar 11, 2005 07:45 PM
