Remote starting bad for CP4?
Old Jan 20, 2025 | 03:09 PM
wcbcruzer's Avatar
wcbcruzer
Has anyone ever hooked up a fuel pressure gauge to see how long it takes the lift pump to build pressure once you turn the truck to the "ON" position?
We do so many things to try to protect the CP4, but I'm wondering if some simple things are overlooked. I noticed with remote starting, it essentially starts the engine right away. I feel like if we "wait to start" the engine a few seconds, it gives the lift pump time to build pressure to prevent the CP4 from running dry. It'll add up over time.
Old Jan 20, 2025 | 04:29 PM
acdii's Avatar
acdii
It starts no faster by remote than by push button. There are check valves in the fuel lines to keep pressure up and prevent air bubbles in the fuel lines.
Old Jan 20, 2025 | 05:05 PM
FishOnOne's Avatar
FishOnOne
The only thing I do special for my CP4.2 pump is to prime the fuel system by cycling the key 10-12 times to purge out any air in the system after a filter change.
Old Jan 20, 2025 | 08:31 PM
1olddogtwo's Avatar
1olddogtwo
To his point, If the fuel backed away from the CP4, The truck would stumble with air as the lift pump caught up.
Not only that check valves, but you would need air between the cp4 and the injectors. The vacuum alone would hold the fuel in place. Now if you would a leaky injector air could in theory, but the check valves would hold the fuel between the filter housing and the lift pump to the CP4. Now of your injectors are leaking down, You have other issues.
Old Jan 21, 2025 | 10:56 AM
FishOnOne's Avatar
FishOnOne
One could say, the remote start process could be better for the CP4 in extreme cold temps, because if the truck determines if the glow plugs need to turn on due to ambient temps, it will allow the glow plugs to turn on for a bit and then start the truck. This additional glow plug on time will ensure that the CP4 has full input fuel pressure from the lift pump which can't hurt.
Old Jan 21, 2025 | 12:07 PM
4wd6.7L's Avatar
4wd6.7L
It sounds like the OP is describing the difference between hitting the start button, waiting, then placing foot on the brake and pressing the button again. Versus remote start, which is essentially the same as placing a foot on the brake and pressing the start button.
I have always hit the start button first with foot off the brake, pausing for several seconds, before going ahead and actually firing it up with foot on the brake. Not with CP4 in mind, that's just how I have always done it. Ford actually had an instructional video describing this method of starting a push button start vehicle. I believe it was for the diesel F-150, but I could be mistaken.
Old Jan 21, 2025 | 12:16 PM
acdii's Avatar
acdii
Truck determines this regardless if Remote start or PBS. It will still delay startup while your butt is in the seat until it determines the amount of GP time to warm the cylinders up. This morning it was 15* in my garage, oil temp was 25*, it paused 5 seconds give or take before it cranked over. If you don't press the brake, the truck will just go ignition on, but not in to a start mode, so you aren't doing anything other than burning battery. The Glow plugs only come on in a start mode, foot on the brake and button pressed, or remote start mode. Keyed ignitions might go to glow on in the run position, don't know haven't had one since 2012.
Old Jan 21, 2025 | 12:20 PM
4wd6.7L's Avatar
4wd6.7L
Thats not how it works in my '19. Press the start button foot off the brake, glow plug light comes on and then goes off. Depending on temps the duration that the light is on varies.
Old Jan 21, 2025 | 12:30 PM
4wd6.7L's Avatar
4wd6.7L
Here's that video.
Old Jan 21, 2025 | 12:47 PM
acdii's Avatar
acdii
According to the video that you posted after this, if you do not step on the brake, it will not go into engine start mode.
When I did forscan changes, I always saw the GP symbol too, even though it was warm enough not to need them. Doesn't mean they are actually active though. I have the shop manual, maybe the information is in that in one of the diagnostics. Reason I think they don't activate when not in engine start mode is to protect the battery. GP draw a lot of energy.
Old Jan 21, 2025 | 03:35 PM
wcbcruzer's Avatar
wcbcruzer
I've got a mechanical fuel pressure gauge on my 12 valve Cummins, along with an Air Dog fuel pump. I could start that truck right away too since there is fuel in the lines, but on a cold start it takes 2-3 seconds for the Air Dog to start building fuel pressure.
I guess as long as the CP4 cam/lifters are submerged in diesel when it starts turning, then it's fine. However, I bet the Ford engineers figured out some mathematical formula that takes into account inlet flow/pressure through the CP4 to keep it lubricated to compensate for the lower lubricity of US diesel. Maybe it doesn't work that way, but we also don't really see any unusual CP4 failures on these Fords. They've figured something out.
Old Jan 22, 2025 | 06:49 AM
zeroo's Avatar
zeroo
-9f this morning. I was surprised how short the wait was from pushing button til it started. Seems longer when it’s in the 20’s. It was almost instant.
Old Jan 22, 2025 | 09:15 AM
RA033125's Avatar
RA033125
Banned
0000
Old Jan 22, 2025 | 01:06 PM
acdii's Avatar
acdii
Just for kicks this morning I didn't press the brake pedal, just the PBS. Screen lit up but no GP icon. Turned it off and started it as normal, and saw the GP icon. Maybe Ford changed it in the 23 MY to not show the GP unless it is actually lit. I know the 2019 did show it on the dash, even though no power was applied.
Old Jan 23, 2025 | 11:04 PM
andrew8406's Avatar
andrew8406
I thought all of the indicators turned on then off upon turning the vehicle "on" whether starting or not. This happens on any car I've touched in a long time. It's how you can tell if someone has disabled the check engine, ABS, airbag, etc. light... I haven't specifically looked for the glow plug light though, I admit.
Work Truck Fanatic
6.7L Power Stroke Diesel
Nov 17, 2020 09:16 PM
Dwilamowski
Oct 8, 2020 02:07 PM
tjc transport
6.2L V8
Apr 1, 2017 07:51 AM
perryau1996
Apr 11, 2011 11:19 AM
rickeylipham
May 7, 2008 12:29 PM
