Just letting you all know I've been reading all the replies and really appreciate it I've been scouring dealer sites around me (Gainesville FL) to find just the right 150, just not finding it yet (see specs below), so also checking their 250s while I'm there. The '24 350 Lariat we test drove yesterday really impressed me, and we have the funds for it, but it's too tall for my garage and I just don't think I really "neeeeeed" a 250, even tho I kinda want it! Torn ...
Any more ideas or thoughts, including better ways to search for 150's, would be greatly appreciated. I've been scouring so much the past few days, I'm ready!
Order exactly what you want and be patient. If your local dealer can't help you ... some of us are crazy enough to order through Granger in Iowa.
OK I'll contact her. My garage door is the standard 7' high, and my little ol' non-lifted 4x4 Titan only clears it by less than an inch. Search shows the F250 height range is around 4" higher than the Titan's height range ... but really i need to measure the height precisely instead of using ranges, and will do ASAP. My door is adjusted to be allllll the way up, ie the door frame is actually the low point, not the door itself.
2025 F350 max height is 81.4, so technically, you'd clear by approx 2.5 inch (assuming 7' = 84").
(and that claims without options, which weighs more and reduces height I'd guess if you got it loaded up).
If you have std type garage door opener with arm that hangs down, you can replace it with jack shaft opener to get max clearance to door when it is up.
F150 crew long bed with max tow and 3.5 EB would be perfectly fine. Loved mine. I moved up to SuperDuty, it’s a day and night difference in handling while towing. Using it as my daily driver, I do miss my F150. If I’m making twice as much, I would be buying both F150 and a Superduty. 😉
The longer ones do tow and ride a little better but its not necessary. I had a crew 5.5 bed and it did fine. Just because he is looking at lot trucks, just find a crew cab with a 5.0/3.73 4x4 and that will definitely meet his needs.
Anyway, also forgot to mention tow mirrors. You can get them aftermarket, the stock little mirrors suck and its not common to see f150 lot trucks with tow mirrors.
We use f150s at my company and I am really familiar with them.
What is the tounge weight on the trailer loaded? Then look at your payload sticker on a F150. Subtract tounge weight from payload number. Keeping in mind the remaining weight is for passenger weight, gear, everything in pick up bed, etc.
i bought a F150 on a whim and my tounge weight on my Airstream was close to 900lbs with a 1300ish payload I was not even factoring in my 70lb Reese WD hitch. That means I only had an extra 400lbs of payload left. I’m 200lbs dog is 80lbs wife is 130lbs and I was going to max payload. This didn’t include hunting gear, camping gear, firewood…etc. I always have to drive a f250.
it’s all about PAYLOAD, not towing capacity.
Being safe while towing is paramount!
Max Tow/Max Payload combo on a properly equipped F150 will rival the F250 as max tow is 14000 & Max Payload in in the 3000 lb range. The 5.0 has a lower max tow @ 13000 but higher payload of 3325 lbs
At this point in my life I didn't need an F350 6.7 PS, but I wanted an F350 6.7PS & that is what I purchased
I purchased OEM style tow mirrors from eBay for my 2014 F150 & they bolted up perfectly fine; Heated glass and adjustment worked as if it was like it from the factory. Do NOT but the chrome cap version, as they look like garbage in about a year (buddy of mine had those)
Typically the 3.5 EcoBoost is Max Tow with just over 3000 lb payload & up to 14000 towing, while the V8 has 13,000 tow & 3325 payload
Those are both unicorn HDPP trucks. Typically you will see between 1500-1900lb actual payload on a well equipped XLT truck. Mine was 1750 on a 2020 3.5 Ecoboost super crew with the short bed and 3.55 gears. Being at the max was another reason I upgraded to the F250. Nothing like going to the scale before a 3 week trip to Utah and being ~350 over the trucks payload and having to go home and repack. My F250 has a 3550 lb payload so won't ever even come close to that with my current camper.
See when I purchased my 2014 EcoBoost, Max Tow was available on just about all of them in Alberta Canada, but my Payload was around 1850 lbs. If you are ordering a truck, you can order what you want/need to get max tow & max payload. I'm not trying to convince him to NOT buy the F250, I think most people should buy what they want. For example I have absolutely no use, at the current time for the F350 that we purchased in Nov, but it's the truck I have always wanted, I could afford it & it should be the last truck that I purchase, which will be paid off when I retire. Not having a truck payment when I retire will be nice
I have a 350, and occasionally tow a gooseneck horse trailer that weighs 12,000 with Clydesdales in it, but even with my 8300 pound boat, some excess headroom is nice. It just tows effortlessly.
Yep, good luck ever finding an F150 with a 3,000 lb payload, most are sub 2,000 as noted. The 1,750 lbs of payload on yours is very typical for most trucks that people actually buy. While I agree the OP doesn't strictly need a heavy duty pickup for his load, the functional capacity difference between even the stoutest F150 and a base F250 is substantial - don't let things like advertised max payload or advertised max tow capacity fool you.
Dave
Yeah you won’t find one, at least on any lot, with 3,000 payload and 14,000 towing. I wouldn’t want to do either with an F150.
A super crew 5.5 bed 4x4 Lariat will have about 1,600 payload (and those aren’t conservative like an f250). If his 7,000 lb trailer tongue weight is between 700-900 lbs he has more than enough payload though.
That assumes I guess you are not loading up the bed with gear. Doesn't sound like OP will be, but if you are doesn't leave much.......
