No crank upon starting attempt
Old Jan 14, 2025 | 10:27 AM
Born Blue Bob's Avatar
Born Blue Bob
Hello,
I have a 2016 F150 5.0 with 85,000 miles. When it drops below zero it will not crank. Accessories seem to work fine with ignition on, battery is new, cables are clean and tight. Sometimes there is a delay when attempting to start but will crank and fire up as usual. A dash light will say to "turn off power and key to save battery" but that does not make sense if I am trying to start it.
Any thoughts?
Thanks.
Old Jan 14, 2025 | 11:00 AM
scott91370's Avatar
scott91370
Sounds like the voltage might be low even if it is a new battery. If you have a jump box try using it next time this happens and see if the boost helps.
Old Jan 14, 2025 | 05:35 PM
SpencerPJ's Avatar
SpencerPJ
Although new, battery might not be fully charged. I'd start there, put it on an agm charger overnight. When it was replaced was the battery life monitoring BLM reset? It might think old one is still in there. Do you have a meter to test the rested battery voltage in the morning?
Auzcole
56
Nov 1, 2023 02:12 PM
Datsyukfan
2004 - 2008 F150
Oct 20, 2022 09:38 AM
Krocky
Sep 2, 2021 11:51 AM
M.Lusk
1997 - 2003 F150
Jan 31, 2021 08:57 PM
Vaerrex
1997 - 2003 F150
Apr 22, 2014 02:44 PM
