HPOP Hoses
Old Jan 12, 2025 | 12:02 PM
'74 Ford 250 CS's Avatar
'74 Ford 250 CS
HPOP Hoses
Anybody bought any hoses other than OEM? Hard to stomach the price for small hoses and some other sites have them a cheaper. Dieselsite, CNC or Bostech brand?
Old Jan 12, 2025 | 12:07 PM
96SD's Avatar
96SD
Im rocking a set of CNCfab lines. Fine for me.
Old Jan 13, 2025 | 05:32 AM
1994F2507.3L's Avatar
1994F2507.3L
I bought a CNC set for my rebuild.
Old Jan 16, 2025 | 06:14 AM
Edgethis's Avatar
Edgethis
I have the cnc lines also. They work and look great. But i had one grumpy note to add, not necessarily their fault completely. I have RiffRaff plenums, I can not install the one fitting on the head without pulling the plenum to allow the fitting clearance. Drivers side I believe it was.
Old Jan 16, 2025 | 08:36 AM
z31freakify's Avatar
z31freakify
I replaced on both my trucks with OEM lines, they lasted this long why not install what lasted, granted mine were not leaking or anything just replaced them as preventative maintance and kept old as spares.
Old Jan 16, 2025 | 10:15 AM
duck fan's Avatar
duck fan
Because racetruck
OEM are the way to go, they lasted almost 30 years the first time so may as well get another 30 out of them.
https://www.riffraffdiesel.com/hpop-...ine-kit-94-97/
Old Jan 17, 2025 | 09:04 AM
White95PSD's Avatar
White95PSD
thought the same and did the same. Mine weren’t leaking @230k but did them as plan was to replace all wear items. I use RR items for everything I can.
Old Feb 8, 2025 | 11:32 AM
'74 Ford 250 CS
Thanks for all of the replies. January is always a busy month for me so I'm finally getting to this repair. I did buy the OEM. Not saying the aftermarket is not good but I usually get burned trying to save money.
Anyway, passenger side was the most difficult. Driver side was a breeze. Question. What side did anyone use the clamp on. I used it on the passenger side. The old clamps won't go on the new thicker hose. Let me know if I used it on the wrong side. The bag didn't come with instructions.
Old Feb 8, 2025 | 01:15 PM
Hit Man X's Avatar
Hit Man X
Do not forget the front fuel lines while in there. They can and do blow out at the worst time. Same with that high side power steering line.
Old Feb 10, 2025 | 12:15 PM
96SD's Avatar
96SD
I used CNC because my OE were clapped out and leaking along with the pump fittings. With Irate efuel the CNC lines make it super easy to route everything with no lines in the way.
Old Mar 18, 2025 | 06:02 AM
'74 Ford 250 CS
I did find a 3/4 inch clamp at Home Depot that worked. I also got a harbor freight assortment but the biggest was 5/8 inch and was too small since the updated hoses were bigger. I did go with Ford hoses.
Mikhuu
Feb 19, 2022 02:22 AM
Hezrock
Jan 26, 2018 02:31 AM
schlepprock250
Mar 9, 2012 04:48 PM
Diesel_Brad
Mar 12, 2011 11:16 AM
Club Wagon
Apr 15, 2007 01:33 PM
