Fuel gauge
Old Jan 11, 2025 | 06:19 PM
jwdenney2's Avatar
jwdenney2
Fuel gauge
2005 F150 XLT 2WD 4.6L
(does NOT have Flex Fuel)
A few weeks ago I was working under the truck making a repair to the wiring harness (I jumpered around the wiring connector - for the Evap Vent Control Solenoid wire - on the driver's side on the outside of the frame). After the repair I cranked the truck and the fuel gauge was on "E". After killing the truck and jostling the wiring harness connector the gauge started working. After driving it a short while the gauge dropped back to "E".
Since the wiring harness connector under the drivers side on the outside of the frame has given me so much trouble I guessed that the issue was in that connector. I stripped some insulation (didn't cut the wire) from the yellow/white wires, and I jumpered around the connector with alligator clips. When I started the truck the fuel gauge went to "F". I removed the jumper and gauge stayed on "F". Then I cut the yellow/white wire and the gauge stayed on "F". Then I cut the black/orange wire and the gauge still stayed on "F".
I did a gauge sweep check on the instrument cluster and all the gauges checked out okay. I also repaired the two cut wires (made a jumper around the wiring harness connector).
My question: Is the fuel gauge at fault? By cutting the sender wires I don't see how the gauge could read full.
Rad082625
Sep 9, 2023 09:39 PM
bmaltman2020
21
May 6, 2022 06:25 PM
Fordf7001
Large Truck
Feb 25, 2020 01:29 PM
Birken Vogt
Sep 18, 2016 07:35 PM
Recoil
Jul 13, 2009 02:16 PM
