Sponsored by: Real Truck
Leaking antifreeze
Old Jan 11, 2025 | 11:24 AM
MWolf's Avatar
MWolf
1st Gear
Leaking antifreeze
2015 F250 6.2 Super Duty GAS
Mysterious leak.
Just started truck. Heater off
File Type: mov
Old Jan 11, 2025 | 08:43 PM
bajaphile's Avatar
bajaphile
I think you're going to have to pop the hood and take a look. Luckily its coming from the front, so it should be easier to see if its just a hose or the radiator. Coming from the block is a bit more difficult to diagnose and fix.
Old Jan 25, 2025 | 08:45 PM
Roadtriptruck's Avatar
Roadtriptruck
Mysterious leak.
I have what appears to be the same exact antifreeze drip coming from the front driver side, maybe not as aggressive a drip though. Have not been able to pinpoint it BUT I have read quite a bit about how the radiators on the 6.4s are not the best built with the crimped on plastic ends. If yours is that issue and you replace it, I sure would like to know what brand whether it be OEM or an after-market product you go with.
Old Jan 27, 2025 | 12:02 PM
crashz's Avatar
crashz
That's also the location of the radiator drain. Maybe you get lucky and its simply loose?
BTW - the coolant is green on your truck? My 2014 is the Ford orange coolant.
Old Jan 27, 2025 | 07:44 PM
marksman76's Avatar
marksman76
My upper radiator hose inlet on the OEM radiator had a very slight leak.
Eventually my 7.3 iron block overheated.
Bought a new Chinese radiator from 1 800 radiator.
Not quite been a year yet since install.
Daniel Weise
Dec 18, 2020 05:25 PM
Grrrshn
Feb 10, 2014 08:09 AM
kawkx500
Feb 18, 2011 08:12 PM
justin25
Jul 9, 2006 12:58 PM
77hiboyboy
Jan 17, 2005 07:32 AM
