Hubs not locking?
Old Jan 11, 2025 | 12:13 AM
gtg038y's Avatar
gtg038y
Hubs not locking?
Hello!
Last year I went out for an ATV ride, carrying the ATV in my 2021 F250 XL 4WD. I parked on soft soil, apparently with one back tire significantly less loaded than the other. After our ride, I discovered that the XL meaning "Xtra light [on equipment]" extended to the differentials. I never dreamed that a vehicle labeled and sold as 4WD would have a 4WD unit, but only open differentials. Maybe the entire world knew that; I'm sure everyone else here already knew that. But I was horrified when, after engaging 4WD, that lightly loaded tire just spun and my truck went nowhere. Through the rest of 2024 I read a lot and saved up for some quality locking differentials, and thanks to advice on here, I will up gear at the same time as those are installed.
The diffs were ones part of the problem, but the other was that the front axle did absolutely zero. Neither tire moved at all. This revealed to me that, despite being labeled with Auto and Manual settings, the front wheel hubs are NOT, in fact, automatically locking. Manually locking them seemed to help me greatly with maintaining traction on snow and slush in central CO a few weeks ago.
Please help me know what to do about the hubs. Could they or their activation system (pressure, vacuum, electric, whatever) have failed and need repair or replacement? Or is this normal on bottom-tier trim levels? Can AM or OEM locking hubs be installed, either to lock by remote switch or by triggering off of the circuit controlling the locking of the front differential?
Thank you!
Chris
Master of Destruction, Not of Cars
Old Jan 11, 2025 | 02:19 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yes, if your auto hubs are not engaging the front tires when you switch the transfer case to 4WD, then you have a problem somewhere in the system. You can get out and manually turn the dial on the hubs to "LOCK" to get them to work for the time being until you get the vacuum auto system working again.
Old Jan 11, 2025 | 11:05 AM
gtg038y's Avatar
gtg038y
That's the thing: I'm not certain that the hubs on my XL are even capable of remotely or automatically locking. I was badly surprised and disappointed that my differentials are both open, not locking, so I'm doubting that the hubs are anything but the cheapest possible configuration.
How would I verify their configuration? Is there a vacuum system, are there vacuum lines, or anything physical that would definitively tell me if they are capable of being locked my any means other than manually?
Old Jan 11, 2025 | 11:23 AM
kayakingpoodle's Avatar
kayakingpoodle
Why don't you tell us more about your truck, what transfercase what hubs was the truck bought new or used.......
Doing research after the purchase leads to surprises rarely good ones, and not easy on happiness.
Old Jan 11, 2025 | 12:20 PM
shawnee1's Avatar
shawnee1
If you have "electronic shift on the fly" or ESOF 4WD then you have auto locking hubs. ESOF uses a rotary **** on the dash to engage 4WD versus a shift lever on the floor. I think ESOF was the only 4WD system available on the 2021. If your hubs are label with AUTO and LOCKED positions, then you have auto locking hubs.
A locking rear differential was an optional cost item on all SRW Super Duty trim lines. A locking front differential is not offered although a limited slip differential is offered on the Tremor package.
Are you sure your truck does not have a locking rear? The electronic rear differential is engaged by pulling out on the ESOF ****. There will be a graphic to the left of the **** depicting all 4 wheels with locking symbology for the rear and the label PULL.
Old Jan 11, 2025 | 02:02 PM
gtg038y's Avatar
gtg038y
Originally Posted by kayakingpoodle
Why don't you tell us more about your truck, what transfercase what hubs bought new or used.......
doing researcrese after purchase leads to surprises rarely good ones, and not easy on happiness.
Sure! It's a 2021 F250 XL 6.2L gas 6-speed 4x4 3.73. I got it used, just over a year ago, at 56k miles then and at 70k now.
Thanks, but no amount of additional research would've likely changed my choosing this one. I was in the middle of my unfaithful ex-wife divorcing me to pursue the other guy, so my supply of cash and how much truck I could afford were very limited. This F250 was no frills and still a stretch; anything XLT or higher trim, 10-speed, 6.7L diesel or 7.3L gas, were quite beyond what I could afford at the time.
Chris
Old Jan 11, 2025 | 03:13 PM
jimzpsd's Avatar
jimzpsd
I think (from what you described) your front axle did not or could not engage because the front wheels need about an 1/8th of a wheel rotation to "assist" the spline alignment inside the hub. The vacuum was probably pulling the inner gears but the teeth could not line up. This will happen from time to time while sitting stationary. In most case when 4x4 is need, the vehicle is already rolling and everything is in synchronization to make it engage. I'm willing to bet its fine, you just had that bad encounter. In the winter time my hubs are in the "locked" position all season, this way I never have an issue in the ice and snow or a broken vacuum hose, etc.
Old Jan 11, 2025 | 03:37 PM
Superdave71's Avatar
Superdave71
Is it electronic shift on the fly, or do you have a lever on the floor to engage 4x4?
Old Jan 11, 2025 | 04:13 PM
gtg038y's Avatar
gtg038y
It has a basic ESOF; **** style, no lever on the floor. The **** does not pull out, however, and only has markings for 2H, 4H and 4L.
Old Jan 11, 2025 | 05:20 PM
Sport45's Avatar
Sport45
Originally Posted by jimzpsd
I think (from what you described) your front axle did not or could not engage because the front wheels need about an 1/8th of a wheel rotation to "assist" the spline alignment inside the hub. The vacuum was probably pulling the inner gears but the teeth could not line up. This will happen from time to time while sitting stationary. In most case when 4x4 is need, the vehicle is already rolling and everything is in synchronization to make it engage. I'm willing to bet it’s fine, you just had that bad encounter. In the winter time my hubs are in the "locked" position all season, this way I never have an issue in the ice and snow or a broken vacuum hose, etc.
I’m having trouble visualizing this. Why would the wheels have to move to line up splines when the axle shaft inside the hub is spinning? The only way I can see the hubs not locking is if the transfer case doesn’t engage.
Old Jan 11, 2025 | 07:20 PM
jimzpsd's Avatar
jimzpsd
Thats exactly it, the inner gear of the hubs is almost in a neutral position, half way between the two gears. The only way to get engagement at this precise time is to rotate a wheel. I know it complex but its easy to duplicate on ice from a stand still, ....almost like reaching in and rotating the driveshaft manually. Yes the transfer case should do this, but now and then it won't, I've seen this six times already.
Old Jan 11, 2025 | 10:36 PM
kayakingpoodle
Chris
Best of luck on your education.
Old Jan 12, 2025 | 12:15 AM
gtg038y's Avatar
gtg038y
Was "I did the best I could with the resources, options and information available to me at the time," somehow offensive? Or was it my not already having some requisite level of knowledge deemed "acceptable?"
Chris
Old Jan 12, 2025 | 12:22 AM
gtg038y's Avatar
gtg038y
Could I throw it on a lift, get the tires off the ground, spin the wheels to verify they're free, engage 4H and see if they engage? If they don't engage right away, I should then manually rotate the wheels and see if they can then engage?
If I have started to scratch the surface of understanding open differentials, then the opposed wheel should spin the opposite direction of the one I manually spin, correct?
Thank you, Jim!
Chris
Old Jan 12, 2025 | 01:10 AM
gtg038y's Avatar
gtg038y
Manual locking seemed to work fine; I had occasion to use it in the snow in central CO a few weeks ago. I was surprised to find a slight difference in the feel of the truck [edit: on dry pavement, in 2H], how it moved and responded, but I suppose that's all a significant amount of metal to be spinning, when you're not freewheeling.
Do you have any advice on what to look for, regarding the vacuum system? I don't know where to start on a vacuum system, but I'd take a guess that I should look for pressure hoses or lines emanating from near the end of the axle, behind the hub and brakes. (Pressure lines that aren't the brake lines; I've bled & flushed those, before!)
Thank you!
Chris
