Excessive cranking
Old Jan 9, 2025 | 09:06 PM
Sean_Taylor's Avatar
Sean_Taylor
3rd Gear
Excessive cranking
So I installed for the 3rd time new injectors in my 2011 5.0 lariat and I’m getting an excessive crank even after purging the system multiple times. But the moment I put my old injectors in the problem of excessive cranking goes away. All injectors are from the same company. I’m at a loss for words and can’t figure it out. No leaks to the injectors. Fuel pump seems to be priming itself. I replaced them originally because I replaced the engine due to low compression in cylinder 3 in original engine. So I figured I’d replace the injectors. Put the first replacement set in and it did the same thing so I out my old ones back in and the problem went away. I contacted the company to have them send me a replacement set. Figured an injector was loosing pressure. Put the second set in yesterday, primed the system. started right up, Now all of a sudden I’m getting an excessive crank. Anyone else been having this problem?
Old Jan 9, 2025 | 09:13 PM
2jhanna's Avatar
2jhanna
Maybe put all 8 of the original back in, drive it for a few days to insure the problem is solved.
then change one at a time, with a few days in between.
Process of elimination.
Old Jan 9, 2025 | 09:15 PM
Sean_Taylor
3rd Gear
That’s a good point. Will be a little time consuming but a good thought
Old Jan 10, 2025 | 08:15 AM
2jhanna's Avatar
2jhanna
You could swap 4, one side, drive for a few days.
then go from there
if problem returns, swap two of those four, back to old ones.
if problem does not return, swap two of remaining four, with new ones.
process of elimination
Old Jan 10, 2025 | 08:22 AM
Sean_Taylor
3rd Gear
I was gonna tear into it after I got off work and over the weekend, it drives fine going down the road it’s just initial start up that’s when the problem occurs. Only when the engine cools down for about 10-20 minutes then does it again but if I shut it off then start right away starts just fine. So it’s gotta be an injector losing pressure. Just can’t believe it’s been two sets back to back!
Old Jan 10, 2025 | 12:18 PM
2jhanna's Avatar
2jhanna
all it takes is one per set.
53fordman1
Sep 26, 2020 12:40 AM
IHateCommieCars
Sep 17, 2014 05:32 PM
newr
1983 - 2012 Ranger & B-Series
Apr 27, 2010 06:43 AM
aocabrown
Nov 30, 2008 08:00 PM
bassproguy07
Sep 25, 2007 07:05 AM
