Piston Stop and Big Problem
Old Jan 8, 2025 | 05:53 PM
pfeathers's Avatar
pfeathers
My 292 y block on my 1960 Ford F350 does not have clear markings on the crankshaft pulley. I decided to use a piston stop to find my TDC. It was working great, I was moving clockwise and then counter and finding my two marks. I had gone forward and then reverse several times, checking my position on the pulley. At one point while rotating the crankshaft I felt some resistance, I thought it was just compression becasue I was a long way from where TDC should be. So, I muscled it through. I finished my marks and tried to backout the piston stop bolt which should have been easy but the bolt could not be removed by hand. Cleary something had come in contact with the piston stop, there was a nick on the bolt threads I discovered after I removed it. I put the truck back together and started it up and I have noticeable ticking noise, sound ike from #1 cylinder. I am assuming the piston stop came in contact with a value. Any ideas?
Old Jan 9, 2025 | 10:46 AM
f5fordgirl's Avatar
f5fordgirl
Pull that valve cover, most likely if a valve was encountered, a push rod will be bent, replace it and check compression, if good, you may have lucked out and not bent a valve.
Old Jan 14, 2025 | 06:13 PM
mark a.'s Avatar
mark a.
First I'd pull the plug wire off while it's running. If it stops making the noise then move on to a leak down test.
pfeathers
Jan 8, 2025 05:43 PM
Red1111
Mar 3, 2017 11:13 PM
lm987
Jul 3, 2015 08:40 PM
thomgcfour
Dec 7, 2012 06:20 PM
JimNolan
Feb 16, 2010 08:24 PM
