Lead frame needed at 236000 miles
Old Jan 5, 2025 | 07:48 PM
blackestate's Avatar
blackestate
On my 2011 f150 5.0 It looks like I need a lead frame. Truck runs well. But at this milage should I repair it or just replace with a reman transmission?
Thanks for your opinions
Old Jan 5, 2025 | 08:34 PM
RLXXI's Avatar
RLXXI
That question depends entirely on how deep your pockets are. No other answer will do.
Old Jan 6, 2025 | 08:55 PM
newfordy's Avatar
newfordy
That's exactly where I am at this point. 260k on my '14, 5.0.
Likely going to tackle it in couple months. Investment worth it considering cost of replacing truck with newer.
Old Jan 8, 2025 | 07:48 PM
Evan76's Avatar
Evan76
100% replace lead frame. Im just under you in mileage. Just did my lead frame.
Also do the bulk head square seal and bulk head sleeve on harness to valve body . Can also eliminate fluid bypass. I didnt do it ugh.
if its hard downshifting transgo has a fix for it. Inexpensive to.
if you get a new or reman trans itl likely have lead frame issues to.
Old Jan 9, 2025 | 07:25 AM
djwheels2000's Avatar
djwheels2000
6th Gear
2012 5.0 Lariat 161K miles - Had it throw a P0722 code (output shaft speed sensor) - Lead Frame just replaced and fixed the low power trans was producing. This is a known issue with the 6R80 Trans in Fords. Can be done by anyone mechanically inclined and takes about 4 hours. Replace all gaskets if you do so while you are at it. Costs for all parts is about $350. You can go Dorman or OEM. Do a search on youtube for F150 Lead Frames and there are a few good videos showing exactly how and what needs to be done. Unfortunately I travel a lot for work and didn't have time so paid a local place. Bill was $1500 (dude was honest but a little pricy)
Old Jan 9, 2025 | 05:37 PM
Evan76's Avatar
Evan76
I was unable to find oem lead frame amonth ago. The doorman is doing well.
Also had speed sensor code.
for what its worth the lead frame if tripping speed sensor falls under a safety recall. ford will do bandaid recalibration then if that doesnt fix it theyl do the lead frame on theyre dime.
Might be worth. checking out.
I elected to do mine myself over hassling with ford. Cost me 400 bucks. I dont trust dealer techs well most techs in general but thats just me.
Old Jan 11, 2025 | 07:34 AM
blackestate
Thanks. I saw on line that a drain and fill.might help?
I like the truck. But it has rusting cab corners. Is it worth fixing?
I like the no payment as opposed to a newer one., which may have the same issue, without the rust.
Old Jan 14, 2025 | 11:18 PM
Evan76's Avatar
Evan76
I say its worth it
Katmandu
20
Dec 24, 2024 07:13 PM
rastymus
2015 - 2020 F150
Nov 2, 2019 05:12 PM
emeraldcoupe
Mar 11, 2015 01:16 PM
