Sponsored by: Real Truck
weird coolant leak
Old Jan 2, 2025 | 09:11 PM
ggenovez's Avatar
ggenovez
weird coolant leak
Hi all,
I've been chasing a coolant leak for several weeks. Put in some dye and pressurized the system and, where I thought it was coming from the coolant bypass is actually coming from just below that. This is the view from under the truck, and below the bypass.
What is this part? it's a metal cover with a bolt holding it in place. I don't want to take it apart and then be down for a week. Any idea what it takes to fix this?
Old Jan 3, 2025 | 03:42 PM
Rudiak's Avatar
Rudiak
That's a block off plate.
Remove bolt then pry it off, replace o-ring, re-install. Drain coolant first.
Old Jan 3, 2025 | 04:29 PM
ggenovez's Avatar
ggenovez
Someone said that might be an EGR block off plate. There shouldn't bee coolant in that right?
Old Jan 3, 2025 | 04:33 PM
Rudiak's Avatar
Rudiak
Yes there is coolant behind it.
Old Jan 3, 2025 | 04:34 PM
Rudiak's Avatar
Rudiak
EGR COOLER BLOCK OFF PLATE.
Alexis Garcia
May 16, 2024 06:01 PM
Larry1#
Aug 21, 2023 08:19 AM
bdwiggin
Aug 14, 2022 03:48 AM
2fifty
Oct 28, 2017 04:49 PM
cscott952
Oct 27, 2011 11:41 AM
