Coolant leak source?
Old Aug 20, 2023 | 10:49 AM
Larry1#'s Avatar
Larry1#
Coolant is leaking from the housing between the pulleys and the engine. I believe this is that harmonic balancer. What is the fix for this?
Last edited by Larry1#; Aug 20, 2023 at 11:42 AM. Reason: To correct the name of a part
Old Aug 20, 2023 | 04:30 PM
tecgod13's Avatar
tecgod13
Check your waterpump. Often times you get a small leak from the front of the pump before it really craps out. There is a small weep hole there that will drip when the waterpump seal leaks.
Coolant won't come out from the harmonic balancer, it is dripping from higher up.
Old Aug 21, 2023 | 08:19 AM
Olds64's Avatar
Olds64
^^^THIS^^^
You can go to your local auto parts store and rent a coolant system pressure tester. This will make it easier to find the leak.
https://www.harborfreight.com/radiat...kit-63862.html
PwerStroke99
6.7L Power Stroke Diesel
Jan 18, 2023 08:24 PM
EARLY_95_F250_7.3
21
Oct 31, 2022 02:05 PM
JVR
Sep 30, 2018 03:57 PM
tigerlady1221
Jan 27, 2016 04:45 PM
CR3999
Jan 24, 2012 05:32 PM
