Coolant leak
Old Aug 13, 2022 | 05:02 PM
bdwiggin's Avatar
bdwiggin
Coolant leak
Can someone tell me what the highlighted part is? I have a coolant leak dripping from the under side of the cover. Tried taking it apart but the bolts are corroded. Thanks I’m advance for any input.
Old Aug 13, 2022 | 05:36 PM
SFaulken's Avatar
SFaulken
A/C Evaporator. And no, there is no Coolant leaking from it. If there's coolant coming out of there, it's from the heater core, and you get at that from behind the glovebox.
Old Aug 13, 2022 | 07:00 PM
bdwiggin's Avatar
bdwiggin
Coolant is definitely leaking from that box. I assume that would only be possible from a leak in the heater core itself? The two connector hoses are not leaking.
Old Aug 13, 2022 | 08:34 PM
SFaulken's Avatar
SFaulken
I didn't say that coolant wasn't leaking from the box. I said it wasn't leaking from the Evaporator. There is no coolant in the Evaporator, unless somebody hooked something up VERY wrong. The only Engine Coolant inside that box, is in the heater core, which is accessed by taking the glovebox out. You can't get to the heater core, by splitting the box right there where you see the coolant leak.
Old Aug 13, 2022 | 09:12 PM
My4Fordtrucks's Avatar
My4Fordtrucks
If coolant is leaking out of there then, yes. The only part in there is the heater core which is located inside the cab behind the glove box. I can’t believe there isn’t coolant dripping on the passenger side floor.
Old Aug 14, 2022 | 03:48 AM
Prototypemech's Avatar
Prototypemech
Are you sure it coolant and not water? The AC evaporator collects moisture from the air and drains it from a tube near the wheel well into the ground. If the tube it clogged, it'll leak out of the seam in the box.
Alicia Garcia
2015 - 2020 F150
Nov 17, 2022 07:54 PM
Dace
15
Feb 6, 2022 07:39 PM
JVR
Sep 30, 2018 03:57 PM
tigerlady1221
Jan 27, 2016 04:45 PM
brej
Mar 22, 2005 07:45 PM
