Engine stalling issues
Old Jan 2, 2025 | 11:31 AM
Owen_Wilks217's Avatar
Owen_Wilks217
1986 F150 XL 302 EFI
The current status of my truck is better than my last post on this page. My truck currently will run great but only for about a minute or two, once my truck warms up and gets to a good idling temp it begins to misfire and when in drive stall out. I have replaced many sensors including ones I have gotten codes for, which all of my codes still remain even after replacing. I’m not really sure what I should do as I cracked the computer open a couple days ago, there was no damage and all of the pieces seemed to be in good condition. My next move right now is to go through every wire individually and check for grounding issues or bad connections. If anyone has any other suggestions I’m open to hear. FYI I do have the EGR deleted with block off plates to both the upper and lower intake, I’m looking into a plug connector to stop the code but I’m not sure if it’s worth the money just to turn the code off or if it will help other things.
Old Jan 4, 2025 | 06:16 AM
Franklin2's Avatar
Franklin2
Not sure what engine and what model truck you are working on? If I make some assumptions, sounds like you may have a TFI module on the distributor. Have you replaced that?
Old Jan 4, 2025 | 08:49 AM
Max Capacity's Avatar
Max Capacity
I'm guessing, by upper/lower intake, he has a 86 302EFI ?
Old Jan 4, 2025 | 09:38 AM
Owen_Wilks217
1986 F150 XL 302 efi, TFI module is brand new yes.
Old Jan 4, 2025 | 10:17 AM
Max Capacity
Just because it's new, doesn't mean, it's not junk.
Where did you get it from and what brand is it ?
Old Jan 4, 2025 | 10:22 AM
Owen_Wilks217
it’s a Duralast from Auto-Zone, was like $50 I haven’t bad experience with duralast so far I don’t think lol
Old Jan 4, 2025 | 10:59 AM
FuzzFace2's Avatar
FuzzFace2
I think I would clear the codes and go from there.
I think they say you can disconnect the battery for 10 min. hook it back up and see if you get codes.
When you do post them up and I am sure someone will be able to tell what is going on.
Dave ----
Old Jan 4, 2025 | 11:21 AM
Max Capacity
Agree that should be good. ...but nothing is perfect...now days. I know sometimes they don't want to refund electrical parts.
I wonder if there's away to test that part ? I'm not an electrical expert.
Let's see what happens after you do what FuzzFace2 says. Dave is pretty good and one of the "go to guys".
Old Jan 4, 2025 | 11:30 AM
Owen_Wilks217
Dave ----
these are the codes I got when I plugged into the computer last. The TPS is a new motor craft part and it was adjusted to the proper voltage I’m not sure why there’s a code. The MAP sensor is also brand new not sure why there’s a code.
Old Jan 4, 2025 | 12:14 PM
BigBlue2's Avatar
BigBlue2
With all those codes I'll have to ask about your battery, state of charge, connections, wires and condition of your alternator.
If the battery is less than 12.4v you might want to check the electrolyte levels and give it a charge to 12.6v. Then check the charging level while running. Everything off at idle should be north of 13.5+v or more up to 14v.
Old Jan 4, 2025 | 01:18 PM
FuzzFace2's Avatar
FuzzFace2
Oh come on
Was that after all the codes were cleared by disconnecting the battery? Maybe try again to disconnect and when disconnected check the charge and water level in the battery and charge if needed.
After it is charged then hook it back up, get motor up to temp and run the test again and lest see what you get?
I am thinking maybe the codes did not get removed?
Good call on the battery. With computers if the power to them is not good it can cause problems.
Dave ----
Old Jan 4, 2025 | 06:08 PM
Franklin2's Avatar
Franklin2
Code 18 is common. It's what you get when you pull the jumper to set the timing. I agree, pull the battery for a minute and then re-attach it and start it, let it warm up fully, and then pull the codes again.
What is interesting, if you study the diagram below, all your code complaints are fed by the same supply voltage wire. I would see if you have 5v on the orange/white wire that feeds the TPS, the EGR and the MAP sensor. You may have a broken wire or a corroded splice out there. You will probably be unwrapping the large harness and tracing wires to check this along with your voltmeter.
P,S, Looks like the negative for the 5v is the black/white wire. The diagram says you can pick this negative wire up off the self test connector you have been using to pull codes.
Tomget
1983 - 2012 Ranger & B-Series
32
Apr 11, 2015 08:41 AM
4.9inline6
Jun 2, 2006 06:16 PM
2kstroker
Nov 16, 2005 02:53 PM
dr9999
General Automotive Discussion
Nov 10, 2005 05:19 AM
Whou4
Aug 19, 2004 12:44 AM
