Spring perch
Old Dec 31, 2024 | 01:06 PM
LONCO's Avatar
LONCO
Spring perch
Does anybody know if an axle from a 2008 E350 Dually with bolt in place of the rear axle on my 2019 E350 dually van. The shop spun a rear bearing and damaged the spindle.. I do not have either axle to measure the spring perch width.
Old Jan 1, 2025 | 07:46 AM
manicmechanic007's Avatar
manicmechanic007
I do not know
But
I doubt it
Check with a junkyard and check their interchange info
Call or visit a Ford parts department
11 years later, there's bound to be something different
Even something like the ABS sensor can screw you
Just get the absolute correct axle at all costs is my 2 cents
Old Jan 1, 2025 | 11:31 AM
LONCO's Avatar
LONCO
Thanks
Old Jan 2, 2025 | 08:25 AM
manicmechanic007
I go to a junkyard around here twice a week some weeks, and sometimes months in between but it's close
I can ask them
You need the axle code off your door jamb to know what axle is in it
Then you can run an interchange search
Maybe post that axle code
Old Jan 2, 2025 | 11:17 AM
Mike1's Avatar
Mike1
I would think it would be fairly cheap and easier just to buy a new rear axle and or bearing kit. So I guess the question is, Is it the Rear Diff housing that's buggered up and needs replacing or can it be as simple as replacing the the bearings and races with new axle(s)??
Old Jan 2, 2025 | 11:37 AM
LONCO's Avatar
LONCO
Supposedly, the shop owner has a lead on a replacement axle. And new bearings as well.
Old Jan 2, 2025 | 11:54 AM
Mike1's Avatar
Mike1
Well you never know the quality of parts you buy any more, but Going over to partsgeek.com Your axle was as cheap as $156.00. But Rockauto.com also has good prices on bearing and axle shafts too.
petalumaboy
Ford Truck Parts for Sale
Dec 8, 2017 08:26 PM
HD RULES
Mar 5, 2013 04:38 PM
npccpartsman
Aug 7, 2009 09:37 AM
usmcBTC
Jun 7, 2009 06:08 PM
