rear differential
Old Dec 31, 2024 | 06:34 AM
buddyrow's Avatar
buddyrow
Nice collection
I will
Old Dec 31, 2024 | 10:35 AM
tbear853's Avatar
tbear853
Long ago, so long that I really should repeat, I went to change the rear lube in my '77 with 9". A hose to suck out the old didn't want to turn down between the ring gear and fill opening, so that time I used a 3/8" copper tube smoothly bent and it "seemed" to do OK, hose was attached to tube outside the axle housing.
But I also need to at sometime, replace that pinion seal. When I do, after parking the truck where I want to work, setting the park brake, and anything else needed to secure it like placing it in 4x4 with front hubs locked and transmission in "Park".
I am not going to take the pumpkin out, but I will clean it all with U-joint and drive shaft tied up out of my way.
I will:
  • both count exposed threads and measure the length of exposed pinion shaft, and record both.
  • punch mark the pinion shaft end and the nut and the yoke itself so that when I put it back together, I can put it together EXACTLY in the same orientation.
  • just loosen the pinion nut
After the pinion nut is just loose, then I will:
  • remove the 5 smaller bolts and take pinion carrier out with drain bucket under it (allow to drain) ... & then I can use a siphon to draw out any remaining old lube (that didn't already run out).
  • remove the pinion carrier and tag / secure any shims after all is safely & legibly recorded,
  • take the carrier inside my shop to R&R the seal without any extra disassembly outside.
  • save / maybe even tag ... any washers.
  • have both the pinion carrier's "D" (cross section) shaped O-ring and a pinion seal ready.
  • reassemble loosely and reinsert the pinion into the rear once the pinion and its carrier and any shim(s) found are back in place.
  • tighten those 5 smaller bolts to torque (but I'll look up the torque for those 5 smaller bolts)
  • tighten that large pinion nut back to EXACTLY where I found it using the information I recorded earlier.
  • punch a thread so it doesn't back off or use a bit of thread locker, and NO EXTRA TORQUE.
  • refill the rear axle with fresh lube through the fill hole.
  • put in 2x4, unlock hubs, put something in neutral, park brake set though.
  • reattach my driveshaft & U-joint
  • be done then
I'm gonna study on ways to add a drain to the housing while the pinion carrier is out. Might just be a 1/2"-20 threaded hole and a nut welded to the housing down low and a 1/2"-20 magnetic drain plug? Depends on "room" inside.
jopiel
Feb 17, 2008 05:43 AM
nc150
Mar 14, 2006 09:23 PM
Big Rig
Modular V10 (6.8l)
Aug 24, 2005 11:39 AM
mds01
1978 - 1996 Big Bronco
Dec 5, 2003 11:24 PM
bcf
Oct 19, 2003 11:03 AM
