Got too close trying to squeeze my 2021 KR f250 into my spot in my driveway and damaged rear tail light.
I super glued the broke part in, but wanting it "proper" without spending $2k.
Blis module not damaged.
Have any of you tried the aftermarket Ebay options. Have also found LED oem, used tail lights sans the blis module...has the opening for a "reasonable " price.
Ive used the non LED EBAY option- just moved over the BLIS stuff and they worked great....
I just put one on mine and it does work but I can tell the red is not as bright as on the OEM. The Ebay version ($245) is red only while the OEM has some yellow mixed in. The difference isn't enough for me to change it.
