Differential oil
Old Dec 27, 2024 | 01:21 AM
dino360's Avatar
dino360
Differential oil
I just had my 2017 F150 re geared to 4.56 to accommodate 35 inch tires. I used yukon front and back and also added a ford performed Torsen style locker up front. The rear has the factory electric locker that comes on the FX4. I'm planning to change the diff oils after the break in period and I'm wondering if these will require the friction modifier. I am considering Royal purple which already has friction modifier but I'm not sure if it's the correct type or not. Any suggestions ate appreciated.
Thanks
Old Dec 28, 2024 | 11:17 AM
JKBrad's Avatar
JKBrad
For the rear, no. For the front, I believe the Torsen unit is sorely gear based with no clutches. In that case no friction modifier would be needed.
pepito113
2004 - 2008 F150
Feb 7, 2013 09:35 PM
ssrider
2004 - 2008 F150
Mar 2, 2011 01:01 PM
dwild
1997 - 2003 F150
Sep 22, 2009 07:58 PM
jjed2007
Oil & Lubrication
Feb 27, 2008 02:47 PM
jonrob
1997 - 2003 F150
Jul 28, 2007 09:20 PM
