Transmission problems
Old Dec 26, 2024 | 02:24 PM
Johnf2501996's Avatar
Johnf2501996
4th Gear
Hi, I have a 1996 F250 with a 351 Windsor. It has a e4od transmission, and it will not shift out of 1st unless I do it manually. If I put it back into drive it will stay in 2nd and drop back into 1st when I slow down enough but it won’t come back out of 1st until I shift it manually again. Does anyone have any ideas to what is wrong?
Old Dec 26, 2024 | 02:31 PM
tjc transport's Avatar
tjc transport
i ain't rite
you nee dot get transmission trouble codes read.
that will give you a starting point.
Old Dec 26, 2024 | 07:46 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
No 1-2 up shift, can be a large list of possibilities. If you're not getting any codes, post back and if you feel comfortable dropping the pan and removing valve bodies, I can help direct you if you want.
Old Dec 27, 2024 | 02:09 AM
Scndsin's Avatar
Scndsin
75%-90% E4 problems in these things are electrical.
Damaged wiring/connectors, miss-adjusted/failing MLPS, computers failing with leaky capacitors.
As said, read codes. No codes, trans codes or a boat-load? Open computer, inspect for leaky capacitors.
Repair/replace. Inspect PSOM as well.
Free advice from someone who rebuilt an E4 & had the same problems after.
Current thread w/same basic problems & offered solutions for your perusal:
https://www.ford-trucks.com/forums/1...od-issues.html
Good luck.
Old Dec 27, 2024 | 07:03 AM
manicmechanic007's Avatar
manicmechanic007
I would inspect and clean the connector going into the E4OD transmission
See if the connector is full of trans fluid
You really need a NGS to check trans codes (easily) on a 1996
I advise too, that you get the codes read, anyhow, anyway you can
CaptainChaos
Jan 8, 2024 10:24 PM
Righoom
Jan 3, 2023 04:32 PM
SoaDMTGguy
Feb 19, 2021 06:56 AM
digr
Apr 24, 2004 03:00 PM
