Fuel pump PWM control help
Old Dec 26, 2024 | 01:40 PM
hivoltj's Avatar
hivoltj
Hey boys, me again. The guy swapping a 6.2 from a 2018 f250 Lariat.
I'm thinning the wire harness and have some questions about fuel pump control that the wiring diagrams don't quite explain.
I'm eliminating the body control module and making my own fuse/relay panel. Not sure if I'll retain the stock fuel pump or convert to a return system.
It looks to me like the PCM uses 2 micro relays to control the fuel pump relay in the underhood fuse box. I'm assuming the PCM grounds the gray/orange wire to engage the relays? I don't wanna fry my PCM. I'm questioning how to wire up my relays if I keep the stock fuel pump and controller which I think pulses the fuel pump.
Also if i convert to return style can I still use the PCM to control the relay and turn off PWM in the tune?
TIA, merry Christmas
Old Dec 28, 2024 | 01:29 PM
Tom S's Avatar
Tom S
I believe it was Scanner Danner that had some good YouTube videos on Ford style PWM fuel pump controls that might help you.
Team Forsyth
Mar 14, 2024 06:15 PM
MontyHowie
Mar 10, 2023 07:03 PM
stevexcursion2005
Feb 20, 2022 09:50 AM
rangergirl94
18
Jun 10, 2017 09:17 PM
PyroBob
Dec 1, 2005 05:48 PM
