DEF usage
Old Dec 23, 2024 | 01:43 PM
RandyinTN's Avatar
RandyinTN
DEF usage
First time owning a diesel since my 2002. What should I expect for DEF usage when not towing or carrying much weight?
Truck model is listed in my signature.
Old Dec 23, 2024 | 02:48 PM
Selta's Avatar
Selta
From the manual, you have a 7.5 gal capacity, and usage is expected to be:
The usage of diesel exhaust fluid has increased from prior model years in order to meet more stringent emissions requirements. The diesel exhaust fluid usage ranges from approximately 2-6% of fuel burned (100.00 gal (378.54 L) of fuel requires approximately 2.00 gal (7.57 L)to 6.00 gal (22.71 L) of diesel exhaust fluid) depending on vehicle usage. Factors that influence diesel exhaust fluid usage may include:
  • Payload/Towing
  • Driving Style
  • Altitude
  • Humidity
  • Temperature
Old Dec 23, 2024 | 03:05 PM
Strider250's Avatar
Strider250
Hi Randy,
With 20,000 miles on my 23 I range between 750 to 1000 mpg unloaded in mixed suburban and highway use. Towing #7000 I get between 350 - 450 mpg. I keep to the speed limit and I mostly drive conservatively.
Old Dec 23, 2024 | 03:13 PM
Euroman's Avatar
Euroman
Mine’s a 2015, I’m getting around 2k miles per gallon, mainly running light around 60mph.
Old Dec 23, 2024 | 05:31 PM
RandyinTN's Avatar
RandyinTN
Thanks guys. Look like it might take me half a year to empty the first tank!
Old Dec 23, 2024 | 05:53 PM
Flatland1's Avatar
Flatland1
2 boxes......7 gal. is 7000+ for me.............unless I'm pulling something..........
Old Dec 26, 2024 | 03:19 PM
acdii's Avatar
acdii
728 MPG on mine which is a SO DRW.
Old Dec 26, 2024 | 05:29 PM
Painted Horse's Avatar
Painted Horse
I'm just past 40,000 miles on my 2023 F350 HO
Empty, I'm averaging 800 mpg of DEF
Towing my 13,000 lbs GN horse trailer around Utah ( plenty of 7% grades) I average 350 mpg of DEF
The biggest problem with DEF on the 23+ trucks is the algorithm they use to calculate distance left in the tank. It just takes one really hard climb pulling the trailer for the computer to pop up and say 500 miles to De-Rate. Then I drive 500 miles and it still only takes 3.2 gallons to top off tank. It seems to do all calculations based on your worst consumption and once the light pop's on, it won't recalc until your fill the tank again.
Gary Mire
6.7L Power Stroke Diesel
Feb 26, 2015 11:03 PM
Texas Chain Ring
General Diesel Discussion
16
May 9, 2013 10:56 PM
LSO1123
Sep 7, 2011 11:14 PM
Gagew90
30
Oct 26, 2010 06:06 AM
biz4two
50
Aug 24, 2010 11:19 PM
