Sponsored by: Auxito
Stripped allen head
Old Dec 23, 2024 | 09:39 AM
waldo16's Avatar
waldo16
Stripped allen head
Any suggestions on how to get this stripped allen bolt out? I was draining the coolant in the engine block and ended up stripping it.
Old Dec 23, 2024 | 09:42 AM
Don Ridley's Avatar
Don Ridley
Torx bit plus heat.
Old Dec 23, 2024 | 08:51 PM
Mountain Whiskey's Avatar
Mountain Whiskey
One of these.
Old Dec 24, 2024 | 04:20 AM
manicmechanic007's Avatar
manicmechanic007
You need to use the torch 'before' you strip the Allen
Now, you need to drill it out
Block plugs are the hardest plugs in the whole world to remove
Use tons of heat first, and use the best tools you have
Most of them never come out
Old Dec 24, 2024 | 08:32 AM
BareBonesXL's Avatar
BareBonesXL
Leave it there. They're hard to get out because they weren't meant to be removed.
Old Jan 19, 2026 | 08:09 PM
SDDL-UP's Avatar
SDDL-UP
I couldn't leave them there either! I didn't have access to a good torch so ultimately ended up using a carbide burr on my Dremel tool. Slowly and patiently cut it away until I could peel the thread out of the block! Block threads were undamaged and STAINLESS STEEL went back in.
Old Jan 20, 2026 | 03:10 AM
manicmechanic007
Wonderful
So, that's one more that came out and got replaced the hard way
That makes 3 in 40+ years I've seen or heard about being removed
I quit trying in 1976 with a 289
Basically, futile unless you are willing to grind or torch for hours
I do like newer Toyotas with pet***** on the blocks
Old Jan 20, 2026 | 03:11 AM
manicmechanic007
Hey google
petcock is a noun
Old Jan 21, 2026 | 06:16 PM
Johnny Paycheck's Avatar
Johnny Paycheck
I’m sure one of these would work if I needed to cajole an Allen screw out
Topec on Amazon. I think I bought one of all their kits. Rounded head extraction? No problem. The chemicals in our warehouses do a number on plenty of stuff.
I wear a lot of rust dust on my gloves when I finish rounding of a hex head that hydrochloric acid rusted the snot out of.
Old Jan 21, 2026 | 09:23 PM
Oregon Kickstart's Avatar
Oregon Kickstart
Amazing how helpful the right tools are!!
Old Jan 22, 2026 | 08:49 AM
Johnny Paycheck
You know it.
f250blueoval
Jun 4, 2024 11:47 PM
KubotaOrange76
66
Jan 17, 2023 10:10 PM
artscott61
Jan 1, 2023 09:00 AM
Dalton Tallent
Oct 15, 2022 06:04 PM
Davey J
Nov 11, 2012 12:34 PM
