LED Headlight swap
Old Dec 21, 2024 | 09:19 PM
dturner611's Avatar
dturner611
4th Gear
LED Headlight swap
Hello, I have a 2024 F250 XL and I just swapped out the stock low beam headlights to LED. The headlights work, but now when I switch on my light bar I get a buzzing sound from under the dash near the Light bar switch. The light bar is connected to the high beams so it can only be used when the high beams are on.
The buzzing is only when I switch on the light bar, and not when I just have the high beams on.
The buzzing was no there with the stock low beams.
Anyone have an idea what might be causing this?
Old Dec 22, 2024 | 03:49 AM
Zork's Avatar
Zork
Where is the light bar getting its power from? Not the headlights I hope.
Old Dec 22, 2024 | 06:38 AM
SICA526's Avatar
SICA526
Incorrect installation would be causing it
Old Dec 22, 2024 | 06:53 AM
Poncho450's Avatar
Poncho450
You say you swapped out the stock low beams. I'm curious as to if things have changed betweem previous years set up and 2024. Previously the halogen headlight trucks used H13 bulbs. In those trucks all 4 headlights had both high and low beam. There was no such thing as certain bulbs being strictly high beam and the others being strictly low beam on those trucks.
Old Dec 22, 2024 | 11:12 AM
dturner611's Avatar
dturner611
4th Gear
Light bar was installed by the Fleet company we get our rucks from, so not sure how thy wired it.
Old Dec 22, 2024 | 11:13 AM
dturner611's Avatar
dturner611
4th Gear
the 24 ford f250 have H11 low beam bulbs and they are separate from the high beams. at least in the XL trim level.
Old Dec 22, 2024 | 02:09 PM
Poncho450's Avatar
Poncho450
Thanks. That's why I asked. I'm familiar with 2022 and older halogen trucks but not so much with 23+. My 2023 has factory LED so I haven't really had a reason to mess with them like in previous halogen trucks I've owned.
Old Dec 22, 2024 | 07:52 PM
dturner611's Avatar
dturner611
4th Gear
Problem solved, when i removed the drivers side headlight, the wire for the high beam came apart. once I fixed that everything worked correctly and no buzzing noise when switching on the light bar.
hannahsdad
Jan 22, 2024 01:56 PM
kammrk
Feb 2, 2022 09:31 PM
Schneider738
Sep 19, 2020 03:04 PM
moreammo
Electrical Systems/Wiring
Nov 26, 2015 08:08 AM
BIGskinny
20
Jun 5, 2011 01:57 PM
