Modular V10 (6.8l)
Running... RUFF! 2V 2000 V10
Old Dec 20, 2024 | 10:21 AM
WildFire_V10's Avatar
WildFire_V10
4wd Low
Unhappy Running... RUFF! 2V 2000 V10
Well! After all the dealing with a very messy shop.. Cylinder 10 is fixed after the infamous "Spark plug rocketship" My truck doesn't misfire anymore woohoo!!! Stays at steady rpms... But the nightmare isn't over yet. I've noticed that my vehicle is running very rough in between 800RPMs to 1800RPMs, At idle and in park it does run poorly. On the interstate or roadways around 1500,1400,1300,1600,1700RPM's it's not a huge fan of as it vibrates a little as it would in drive not moving anywhere or in park after the engine has idled down from a start. It has all its glory, V10 Power, back! But I'd sure like it to run properly again and sound good and not vibrate the truck... The air intake wasn't even tightened down from the "Professional shop" After tightening it myself it fixed it a little bit. But still runs very rough... All the spark's and coil packs are in place. Wondering what to look for next, As it ran perfectly before the spark plug blew out. Many thanks!
2000 Ford f-250 6.8 2V V10, 184K
Old Dec 20, 2024 | 11:23 AM
Ted722's Avatar
Ted722
“all the spark plugs and coils are in place”
Were any of the spark plugs or coils replaced?
Old Dec 20, 2024 | 11:25 AM
WildFire_V10
4wd Low
Yes they were all replaced, I’m starting to think they aren’t gapped property’s
Old Dec 28, 2024 | 08:33 AM
Wolverine5873's Avatar
Wolverine5873
4wd Low
I have the same problem has a slight missfire/vibrates. I have changed all plugs and checked the coils with the Matco tool, one didn't light up so changed it, and changed fuel filter. Maybe had it a month now. My check engine light doesn't work in dash, but had it scanned and no codes, but it doesn't run right. [ Wish I could figure out IF coil issue or injector or what it is ?]
Old Jan 5, 2025 | 01:10 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Is the Check Engine light on?
Are there any codes stored?
Are there any misfire counters incrementing?
V-10 runner
Modular V10 (6.8l)
Nov 14, 2024 11:16 PM
Firefighter 1406
Feb 28, 2016 04:09 AM
joeskeeter
Modular V10 (6.8l)
15
Mar 28, 2011 08:27 AM
medicdave
Feb 8, 2010 01:16 PM
Musicman250
Modular V10 (6.8l)
30
Mar 21, 2006 11:03 AM
