Parameter Reset after Engine Replacement
Old Dec 17, 2024 | 11:44 AM
Packerl0ve!'s Avatar
Packerl0ve!
1st Gear
Hello,
We have a 2016 Ford F250 Superduty XLT 6.2L Flex Fuel Engine. When we bought it in June it had 140k miles on it, it died 6 days later after purchase. Because we are in the state of TN, there isn't a lemon law and we couldn't return it. So, we had it in several shops and the diagnosis was engine misfire and that we were told that we would need to replace the engine, which we did.
The engine was replaced with a 2019 Ford F250 engine with 55k miles on it. Now that we have it back after engine replacement, we are still getting a misfire error code for the 7th cylinder. We replaced the catalytic converters and upstream and downstream Oxygen sensors. Still throwing the code.
I called the guy who replaced the engine for us, and he said he wasn't able to rest the keys and perform a parameter reset of the new engine. So he said that we need the following: Parameter Reset and Calibration update per misfire TSB - as built data resinstalled and a 2 key operation reset. We will need a misfire relearn to be performed during the reprogramming.
I am having a hard time finding someone who can do this for a reasonable price. Everyone wants $800-$1000. I am not looking to invest much more money in this truck because it has been such a problem child we want to sell it after we can get the check engine light cleared out.
Can anyone help me out with recommendations. Is there any way I can do this myself if I can order the right instrument?
Last edited by Y2KW57; Dec 17, 2024 at 12:18 PM. Reason: Broke up single block of text into separate paragraphs while verifying topic relevancy in the 2017+ forum
Old Dec 18, 2024 | 01:50 PM
muisejt's Avatar
muisejt
you could do it yourself but you'll end up spending at least that to get a scan tool that can do those things
Old Dec 18, 2024 | 02:42 PM
jcb804's Avatar
jcb804
2016 and 2019 engines in long block form are not directly interchangeable, the camshafts are different. If the 2019 engine was installed as a long block (oil pan up to valve covers) then you have camshafts that dont match the 2016 computers timing parameters. Verify that you have 2011-2016 parts from the cylinder heads up, otherwise you'll never get it timed correctly and waste money on the recalibration.
In long block configuration, cylinder heads, camshafts, and valve covers are the only actual different parts between 2011-2016 and 2017-2022 generation 6.2L. The outside sensors are the same and will plug in without issue leading one to believe its a match, when its really not.
Old Dec 18, 2024 | 09:35 PM
leadmic's Avatar
leadmic
Someone else had this issue awhile back putting a newer engine in an older truck and getting misfire code. If I remember correctly, it turned out that the knock sensors from the newer engine were not compatible with the older truck and caused the misfire codes. If you search the 6.2L engine forum you can probably find it.
MarcusB1234
Feb 26, 2022 07:45 AM
eomaynard
2009 - 2014 F150
16
Apr 8, 2021 05:09 AM
eomaynard
2009 - 2014 F150
Apr 4, 2021 09:48 PM
4x4countryboy
Jul 2, 2012 01:15 PM
laptopgeek
May 7, 2002 08:12 AM
