Adding front driving light bar
I wired them to 3 upfitter switches for clear, amber, and DRLs (clears only) and am quite happy with their performance. The biggest issue I faced was that the center lamp blocks the forward-facing camera. In order to solve that problem, I re-located the camera to the inside of the center lamp (visible in the picture above) by modifying the reflector, 3D printing a support bracket, and purchasing an extension cable and camera-less grill badge (P/Ns L1MZ-18812-BAAB & PC3Z-8213-B respectively). The resulting camera position is almost precisely at the stock height and only a few inches further forward, and the 360 degree view is therefore preserved with almost no distortion. There was quite a bit more to it than that, and maybe something I'll create a dedicated thread to explore...
The SAE versions put out 45% less lumens. They said the bulbs on the SAE versions are hardwired to the circuit board and cannot be upgraded. If a bulb burns out, the entire light must be returned to BD for repair. They said the SAE lenses are what give the horizontal cutoff, which is primarily what allows them to have the SAT/DOT approval. However, if a lens cracks, you have to send the entire light to BD to have them replace the lens because, they said an end user replacing the lens could get the alignment wrong and the horizontal cutoff could be askew. I'm trying to envision Bubba, the end user idiot, who can't figure out how to remove four screws and install a new gasket and lens. ",,,here, hold my beer, I don't wanna spill it!"
Since the lens is what creates the horizontal cutoff, why not pair the normal lumen output of the non-SAE lights with the horizontal cutoff of the SAE lights to get the best of both worlds? Question is, how do you get the SAE lenses?
Otherwise, I ask myself if this SAE thing is really that big of a deal. I've seen a lot of after market fog lights this past week or two that were clearly non-SAE.
If you get in an accident, everyone is going to say you were using offroad lights, on the street.
I have also have two Rigid SAE D-Series and two SAE 6" E-Series on the same lightbar. Both have a sharp cutoff, and are actually pretty dim. They both can be triggered independently or I can trigger them with the high beams. I leave these two sets on all the time and have yet to have anyone flash their lights at me.
All are switched through two Garmin PowerSwitch units that are controlled by the CarPlay built into the truck's radio. It actually operates from the radio to my iPhone then into the Garmin GPS's. I used color coded 14AWG wire, which is a bit overkill based on the amperage draw of each of the lights, but I wanted a safety margin before the wire became a fuseable link and melted. I install a T&E fuse block so all lights are protected by 15A micro fuses since the Garmin GPS cranks out 40A per circuit. Everything is modular and connected by waterproof AT/DT Deutsch connectors; a pain to wire, but much easier for final assembly and troubleshooting. The strain relief connectors are impossible to seat the female pins into, so I separated the strain relief, fed the wires through it and into the plug, then re-attached the strain relief. That worked much better.
I custom fabricated the mounts for the two Garmin GPS's and the T&E fuse block out of 5052 aluminum using a Swag Offroad press brake in a Harbor Freight 20-ton press. All the relays are on a piece of 5052 mounted below the radiator, which is held by two stainless steel hitch pins and can swing down for easy access for changing relays when needed. Worked great, since I don't want a winch.
It shouldn't be hard to manufacture lenses and reflectors with the sharp cutoff, but still use the 6000-9000 lumen LEDs. That'd be nirvana I guess.
I want to add a light bar to the front of my 24 Lariat. Problem is the logical location (labeled #2 in pic) has very limited space and will only support about a 12 inch width light bar. I was wondering about the possibility of mounting a longer light bar in either the #1 or #3 locations. Any suggestions? I would love to see pics if you've got something installed. I searched the "What have you done..." entries and only saw one with a 12" bar in the #2 location. TIA.
Find yourself a nice flat wall, and level surface to park on, in a dark area and adjust them per the recommendation in the owner’s manual and you might be surprised at how much better they are at lighting up the road. The lights on my truck were way low when I bought it. While I have seen some folks over the years posting up pics of their aftermarket lights at night, many were not any better than the OEM LEDs. Here is a pic of properly aligned OEM lights,
Keep in mind, it’s not about just mounting up as many lumen as you can because this number can be deceiving and different lights are made for specific lighting patterns and the speed at what you plan on driving while using them. Baja Design is close to me so I was able to drive down and tell them what conditions I wanted to address and they recommended the best option. I went with two lights on the front with amber covers and they have worked well when needed. Here is mine when running with my OEM lights and BD lights on low beam for fog and blowing snow. I also have a small light on each side and two small lights in the rear when needed.
In the mean time, I'm likely going to drop BD SAE fog lights in the factory location. Someone mentioned earlier in this thread they thought the SAE's could be converted to normal Squadrons and I'm not sure that's the case. The lenses are different but the circuit board itself is also stamped differently. They may very well be the same LEDs just with a different lens but they are stamped differently.
I have seen a few put a light bar on your position #1. They just bolt the mounting bracket right to the top side of the bumper where that plastic pad is and it works. Position #2 can be used to put a short bar in that space or get a mounting bar that runs across and connects where the tow hooks are if you want to run a Ford Super Duty Lightbar for a longer light or more round/square lights. I have seen one person mount lights on #3. That may work depending on the type of conditions you may encounter while driving.
