Sponsored by: Real Truck
7.3 no boost, fuel issues???
Old Dec 13, 2024 | 02:17 PM
Brian59222's Avatar
Brian59222
1st Gear
I have a 01 7.3 just replaced up pipes, EBPD, a 66/88 turbo housing, now I’m not really building boost, I make around 5psi at 2500rpm, boost gauge worked before I did the work, I checked all boots, I checked the wastegate and that’s not stuck open. there is no leaks anywhere. truck smokes black. I can hear the turbo whistle around 1k rpm after it goes above that I can’t hear the whistle anymore. when I romp on it, I did notice my fuel pressure gauge will drop to around 40psi, would my fuel pickup screen cause my truck to not build boost like it’s been, I have unplugged the MAP sensor and truck doesn’t seem to get better, map line is not clogged, if someone can point me in the right direction
Old Dec 13, 2024 | 07:57 PM
INFRNL's Avatar
INFRNL
Low fuel pressure can cause your issues. I would get that resolved and see what happens.
A simple trick to see what way the issue is would be to disconnect the fuel line from the rear of the pump and run a hose to a fuel can. if the truck still acts up; its from the pump forward. If the problem goes away, then its in the tank
Capt'n Jack
May 17, 2021 06:28 PM
Ken99F350dually7.3
16
Oct 25, 2019 06:23 PM
Jesse73iditurbo
13
May 15, 2016 03:38 PM
rokinfarmer
Jan 24, 2014 12:23 PM
cornfiled stroker
Aug 23, 2010 05:04 AM
