Forscan issue
Old Dec 10, 2024 | 07:51 PM
Jacobcov1's Avatar
Jacobcov1
7th Gear
Forscan issue
Can anyone help. I’ve had the trial and bought the license. Here are two photos of all computers I can see. I have read threads galore as I may not have seen them all I read what I can find. Why can’t I find the IPC
i have updated Forscan. Deleted my truck. Reuploaded. I have OBDLink EX (elm327)
I wanna find the ipc to turn off a few settings like door chimes etc.
Old Dec 10, 2024 | 07:57 PM
Jacobcov1's Avatar
Jacobcov1
7th Gear
Here is my connection settings also
Old Dec 11, 2024 | 06:00 AM
Neohio's Avatar
Neohio
www.DieselCurrent.com
Do you have the switch on your adapter?
Might need to flip it and scan again.
Old Dec 11, 2024 | 07:34 AM
ifrythings's Avatar
ifrythings
You have a very large CAN error % (40.7%) rate, that’s means that at least 41% of the CAN messages aren’t coming through, you need to get that down to ideally zero before trying to do anything on your truck.
Your adapter settings should look something like this
You may also have to update your adapter to get it to function properly, forscan should do this for you and hopefully you don’t have a knock off adapter.
Old Dec 11, 2024 | 10:05 AM
longhaultransport's Avatar
longhaultransport
This image shows a bluetooth adapter is connected.
Are you trying to do this with a wireless connection?
Old Dec 11, 2024 | 10:22 AM
acdii's Avatar
acdii
Update your dongles firmware.
Old Dec 11, 2024 | 11:28 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
What adapter are you using?
ZooDad
Old Dec 11, 2024 | 01:51 PM
Jacobcov1's Avatar
Jacobcov1
7th Gear
This first is the adapter I’m using. And the 3rd photo is the adapter I got recommended from someone off Facebook. If y’all have another recommendation I’ll order it to and what ever doesn’t work return it.
im using a wired connection. I’m not the best at updating stuff I don’t understand this computer I got enough. I don’t use it. I believe last night I updated my Forscan. I went to website and downloaded the newest version.
if needed treat me as if I’m dumb and I’ll give the best info back I got. And if needed I can get help to update any software needed.
This one is suppose to be an auto one.
Old Dec 13, 2024 | 03:57 PM
Jacobcov1's Avatar
Jacobcov1
7th Gear
I tried it again with the new scanner and I got the same results but better can error %% any other ideas
Old Dec 13, 2024 | 08:01 PM
ifrythings's Avatar
ifrythings
You’re missing a ton of modules, from the looks of it forscan isn’t able to use the MS bus on your adapter.
Make sure you setup your connection page like this
There is also a newer version of firmware for your adapter, yours is 2.3.02 and 2.3.04 is the latest version.
Try those 2 things first and let us know what happens, I have both the adapters you pictured above and they work fine so yours must be a setting or firmware problem.
Old Dec 14, 2024 | 12:43 PM
longhaultransport
FORScan is up to version 2.4.13
Maybe that has something to do with your problem, but not sure about that.
Old Dec 14, 2024 | 02:03 PM
ZooDad's Avatar
ZooDad
Current versions of ForScan
2.3.63 windows version
1.5.25 (lite) iOS version
1.5.25 (lite) Android version
2.4.x is a beta test version that includes advanced programming (modules). It is not recommended for the general user. You can brick your truck !!
ZooDad
Old Dec 14, 2024 | 03:34 PM
Jacobcov1's Avatar
Jacobcov1
7th Gear
Well I got mad and snapped my lap top in half so it’s on pause till I get a new one
Old Dec 18, 2024 | 09:16 PM
Jacobcov1's Avatar
Jacobcov1
7th Gear
Okay I’m back with a brand new laptop. Installed forscan again. Updated my firm ware. Neither one works for me. This is all I get now
bigwin56f100
18
Jul 28, 2023 10:20 AM
MasterX
Nov 30, 2021 02:53 PM
mainefordman
Maine Chapter
Jul 4, 2021 08:08 AM
Myers B
Jul 27, 2020 08:51 PM
ExploringNH
Aug 15, 2014 09:36 PM
