Glow plug stuck
Old Dec 7, 2024 | 11:46 AM
mjunk1's Avatar
mjunk1
Glow plug stuck
2007 F550 4wd trying to change glow plug and harness on drivers side. 2ng plug from the front just spins. The first one was similar but I could pull it out with needlenose. This one doesn't budge. It turns in both directions. The back 2 were pretty loose and came out with oil on them. The first one had caked, thick oil and such.
Any ideas on how to get this 2nd one out? Need it running today.
Old Dec 7, 2024 | 11:52 AM
bismic's Avatar
bismic
Have you used any penetrating oil?
Old Dec 7, 2024 | 12:03 PM
mjunk1's Avatar
mjunk1
A little...I'll fill it up and see
Old Dec 7, 2024 | 12:07 PM
mjunk1's Avatar
mjunk1
Don't understand why I can,both tighten or loosen endlessly though. Can the nut head break loose from the threaded portion?
Old Dec 7, 2024 | 12:23 PM
hobohilton's Avatar
hobohilton
You may need to invest in a broken injector removal tool.
Old Dec 7, 2024 | 12:29 PM
mjunk1's Avatar
mjunk1
Update...I got it to re-tighten. But then tried to loosen again and still can't pull it. I guess I just put it in and leave it be. Unless someone has another idea
Old Dec 7, 2024 | 12:39 PM
bismic's Avatar
bismic
Here is a good thread to read:
https://www.powerstroke.org/threads/...-plug.1376257/
Old Dec 7, 2024 | 01:33 PM
mjunk1's Avatar
mjunk1
Thanks. Out of time so I had to just lock it back down today. Truck only has 60k miles on it so I am a little surprised. But sometimes it just is what it is
Old Dec 9, 2024 | 02:14 PM
Hartwig's Avatar
Hartwig
This is the tool I have built for myself. (Just for inspiration if you want to build something like this)
kd5zll
Mar 1, 2022 07:31 AM
2civicrr
Dec 13, 2014 07:42 PM
TomCat-F350
Sep 29, 2011 03:10 PM
pbuxton
Jan 11, 2009 08:45 AM
