Are glow plug tips magnetic?
Old Feb 28, 2022 | 05:46 PM
kd5zll's Avatar
kd5zll
Just what it says.. are the tips, magnetic. Im missing one, so as i evacuate oil, and try to figure out if the little sucker is in there, or long gone.... im wondering if a magnet would pull it out, or nope?
Old Feb 28, 2022 | 06:40 PM
Walleye Hunter's Avatar
Walleye Hunter
If you have 'er open, it won't be hard to pull another GP and check.
Old Feb 28, 2022 | 07:08 PM
kd5zll's Avatar
kd5zll
Yeah... i did that just now... they are, sort of.... not strongly. Fingers crossed that tip disentegrated and is not present in the cylinder....
Old Feb 28, 2022 | 08:59 PM
Walleye Hunter
If I was in your shoes, I'd get a borescope that will fit through either a glow plug hole or an injector hole and look inside. A little thing like that can be the ruin of your engine. We saw it happen not too long ago with a bolt down a plenum hole. I got one not too long ago that fits through an injector hole but it was over $100.
Old Feb 28, 2022 | 09:10 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
No, the tips are not ferrous (magnetic). The heating element inside is so there is a weak magnetic attraction so long as the glow plug is intact. The bodies and tops are very magnetic.
Old Feb 28, 2022 | 09:33 PM
kd5zll's Avatar
kd5zll
Yeah. I worked on some parts cleaning, etc while i stewed in frustration... but ima go out and get a borescope, and a vac pump.... i had planned to just turn the engine over the clear the fluids... cant do that now, at least until i visually clear number 6.
Old Mar 1, 2022 | 07:31 AM
Walleye Hunter
Make sure you get a scope that will fit through a hole there. I think mine is 5mm, maybe 5.5. I do not know the size of the holes but have heard that not all scopes will fit through. Good luck and update what you find.
idahodisco
Mar 24, 2010 08:47 PM
97biostroke
Feb 8, 2009 01:51 PM
otpracer100
Dec 1, 2007 02:35 PM
