Parking Brake no work
Old Dec 6, 2024 | 10:35 PM
jmwilson06's Avatar
jmwilson06
3rd Gear
Hey all, I have an 84 f250 that the parking brake pedal doesn’t stay down, I’ll press it down and I’ll spring right back up. How do I fix it? Kinda need it to work because the truck is a manual
Old Dec 6, 2024 | 11:09 PM
BigBlue2's Avatar
BigBlue2
Can you hear the clicking as you depress the pedal? Seems there is pawl that catches a gear. Then releases with the T handle to the dash. There is a spring that holds the handle in ratchet mode. Then is released when you pull the T handle.
bump to an older thread:
https://www.ford-trucks.com/forums/1...-assembly.html
Old Dec 7, 2024 | 07:03 AM
FuzzFace2's Avatar
FuzzFace2
You will need to get under when it is pushed to check the pawl & teeth.
Could be the teeth are warn away and the pawl has nothing to grab?
There is play between the pedal and the body at the pivot of the pedal assy. so the pawl / teeth do not line up right.
Maybe it needs a cleaning and lube?
Yep you need to get under there and see what is going on.
Dave ----
Old Dec 7, 2024 | 07:44 AM
Franklin2's Avatar
Franklin2
A little wd40 on the mechanism under the dash may fix it.
KoreanFord
May 19, 2023 04:07 PM
RTT
Nov 26, 2022 09:04 PM
90LBT
Jun 16, 2022 11:30 PM
DWV88
Jun 27, 2010 07:22 AM
