Crank/No Start
Old Dec 6, 2024 | 03:48 PM
MVClassics's Avatar
MVClassics
6th Gear
Crank/No Start
I am chasing a crank/no start issue on the 302 I have in my ‘59 F100. Does anyone know how many volts I should have at the coil? I am showing just 7 at the coil, but the battery shows it’s holding over 12.
Old Dec 11, 2024 | 04:20 AM
Red60's Avatar
Red60
You didnt mention if it was points or electronic ignition. a 302 wasnt offered in '59 so you have a conversion of some sort. Did the conversion also convert the coil to a 12 volt one? Its a lot harder to answer your specific situation not knowing what was done to your truck.
Old Dec 11, 2024 | 07:08 PM
MVClassics's Avatar
MVClassics
6th Gear
Sorry about that. Yes, I have replaced the original 292 with a ‘69 302W. Also, I have replaced the points with a Pertronix ignition set. The battery is a new 12 volt.
Old Dec 11, 2024 | 07:31 PM
FuzzFace2's Avatar
FuzzFace2
When did this start? Was it running with this set up and then next day no start?
Or did this start as you installed the Pertronix IGN?
If you put a little gas or spray starting fluid in the carb what happens?
Dave ----
Old Dec 12, 2024 | 01:22 AM
Red60's Avatar
Red60
Test for spark
Old Dec 14, 2024 | 11:07 AM
lefty1953's Avatar
lefty1953
Two main things will keep it from starting. GAS & Voltage. And the hunt begins.
ynot321AB1
May 29, 2020 06:16 PM
oobical
Jul 18, 2007 11:31 PM
lostinfordland
Oct 2, 2003 04:53 PM
CRJ900
Nov 24, 2002 01:40 PM
