Sponsored by: Real Truck
Fuel problem
Old Dec 5, 2024 | 05:50 PM
Wyatte18's Avatar
Wyatte18
7th Gear
Fuel problem
I have a 2004 f250 super duty 5.4I got it and drove it home and then drove it a little about 3 weeks ago. I sanded the frame and seal coated it now it wont work. Im not sure if the two corrolate. I have a crank no start. The entire fuel pump had been replaced along with filter. I disconnected the fuel line at the filter and tried to start it but it barelt produced any fuel. I think it may be the fuel pump driver but im not sure if it is. Any ideas on what it might be. Does it have a fuel pump driver? If so where is it located? Thankyou.
Old Dec 6, 2024 | 10:00 AM
MotoStu's Avatar
MotoStu
In situations like this where the problem comes up after doing some kind of work on the vehicle, I'd say it's likely related somehow. Make sure ground connections to the frame are good; if you removed any cables from the frame to seal it, you need to clean those areas down to the metal when reinstalling the ground cables. If you disconnected any other cables in the process, go around and ensure the connectors are all firmly seated again.
Old Dec 10, 2024 | 10:25 AM
Wyatte18's Avatar
Wyatte18
7th Gear
Will do thankyou
JAYMONEY
1997 - 2003 F150
Jan 18, 2012 09:11 PM
AFoster1025
Oct 25, 2010 05:48 PM
clwoodall_76
Dec 4, 2009 10:11 AM
D.J
Jan 16, 2008 05:46 PM
mrwrench
May 17, 2004 07:59 PM
